Requesting IPv6 DHCP-PD Prefix Size
WarEagleX
I am able to get an ipv6 /64 address from Xfinity with no problem however I have multiple subnets I need to cover with ipv6 so I'll need a /60 or lower.  How do you specify the DHCP-PD request for a /60 in the RV340 so that I can break up into a multiple /64?
There's plenty of information on how to do it in the cli on a regular router but nothing on the 340 GUI.
Thanks in advance and WAR EAGLE.
Mike T.
I think with IPv6 rapid deployment you can specify the prefix/length (see page 44 of the atrached user guide)...
https://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/RV340/Administration/EN/b_RV340_AG.pdf
Rapid Deployment requires an ipv6 tunnel.  I have this up and running with HE and they allow you to select a /48 from their interface.  This works perfectly.  Xfinity, on the other hand, has no such portal so they rely on the hint command for the client to ask for a block lower than a /64.
Traditional Cisco routers enable the following hint command in the Interface configuration:
ipv6 dhcp client pd hint
I'm trying to understand how to do this on the RV340.  Its the only way to request a /60 from Xfinity.
Make sense?
Makes sense...
Your options regarding prefix delegation on the RV340 are very limited. The only PD related option you have is to specify a prefix name (page 37 step 8 of the attached user guide)...
