Cisco 2621XM Router IOS Booting Issue
Blackbird2018
Hi All
I was wondering if you can help me out, I have loaded ios c2600-ipbasek9-mz.124-25a.bin on the router, for some reason it boots twice as you can see details below, it says %SYS-6-READ_BOOTFILE_FAIL: flash:c2600-j1s3-mz.123-26.bin File boot failed -- File not accessible, but this file is not in flash, than it says boot of "rom" using boot helper "flash:c2600-ipbasek9-mz.124-25a.bin" failed, it than loads again self decompressing the c2600-ipbasek9-mz.124-25a.bin image and than works, dont know why it is loading twice, I have done the following for troubleshootingRouting
1. Deleted the flash, and copied file again.
2. Reset the router to factory default by erasing all config.
3. verified the flash file shown below.
Router#reload
Proceed with reload? [confirm]
*Mar 1 01:31:21.807: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload Command.
System Bootstrap, Version 12.2(6r), RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 2001 by cisco Systems, Inc.
C2600 platform with 65536 Kbytes of main memory
open: file "c2600-j1s3-mz.123-26.bin" not found
open(): Open Error = -1
loadprog: error - on file open
boot: cannot load "flash:c2600-j1s3-mz.123-26.bin"
program load complete, entry point: 0x80008000, size: 0xd06b6c
Self decompressing the image : #################################################################################################
################################################################################################################ [OK]
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
0000A2 0X00103980 C2600 Dual Fast Ethernet
0X00098670 public buffer pools
0X00211000 public particle pools
TOTAL: 0X003ACFF0
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 3Mb.
Using 5 percent iomem. [3Mb/64Mb]
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
%SYS-6-READ_BOOTFILE_FAIL: flash:c2600-j1s3-mz.123-26.bin File boot failed -- File not accessible.
%SYS-6-BOOT_MESSAGES: Messages above this line are from the boot loader.
error returned: File boot failed -- File not accessible
boot: cannot load "rom"
ID MEMORY_REQ TYPE
TOTAL: 0X003ACFF0
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C2600 Software (C2600-IPBASEK9-M), Version 12.4(25a), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 22-May-09 21:06 by prod_rel_team
export@cisco.com.
Cisco 2621 (MPC860) processor (revision 0.0) with 61772K/3764K bytes of memory.
Processor board ID JAD062204K3
M860 processor: part number 0, mask 49
2 FastEthernet interfaces
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
Press RETURN to get started!
Router#verify flash:
Verify filename []? c2600-ipbasek9-mz.124-25a.bin
Verifying file integrity of flash:c2600-ipbasek9-mz.124-25a.bin........................................................................... -..............................................Done!
Embedded Hash MD5 : D5426CFAF460867D3F08B8EB64653834
Computed Hash MD5 : D5426CFAF460867D3F08B8EB64653834
CCO Hash MD5 : FB354413A70D41161015803FE728D8F5
Embedded hash verification successful.
File system hash verification successful.
Router#sh hardware
ROM: System Bootstrap, Version 12.2(6r), RELEASE SOFTWARE (fc1)
Router uptime is 4 minutes
System returned to ROM by reload
System image file is "flash:c2600-ipbasek9-mz.124-25a.bin"
export@cisco.com.
32K bytes of NVRAM.
Router#
Issue was resolved by entering write erase on the router.
johnlloyd_13
Level 9
Level 9
hi,
you'll need to remove the c2600-j1s3-mz.123-26.bin IOS from the boot sequence, i.e. using the no boot system flash:c2600-j1s3-mz.123-26.bin
The no boot system flash has fixed half the problem still getting below error, and than it works after second image decompression.
Router#reload
*Mar  1 01:33:15.167: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload Command.
Self decompressing the image : ################################################################################################################################################################################################################# [OK]
  ID            MEMORY_REQ                 TYPE
TOTAL:          0X003ACFF0
export@cisco.com.
error returned: rom
  ID            MEMORY_REQ                 TYPE
TOTAL:          0X003ACFF0
           cisco Systems, Inc.
export@cisco.com.
32K bytes of NVRAM.
