Resetting embedded ap in 1941w router - how to?
radiomean
I have a 1941W router with the embedded ap, purchased second-hand.
The router part of it is working fine, but I can't access the embedded ap - there is a user and password set and I obviously don't know this.
I have tried with the default that I have found of cisco/cisco but that does not work.
I've tired resetting the ap to default with -
service-module wlan-ap 0 reset and
service-module wlan-ap 0 reset default-config
but neither seem to wipe out the config....
I can (I believe) get to the rommon equivalent by using the command:
service-module wlan-ap0 reset bootloader
but I'm not sure how to proceed from there.
Any pointers would be greatly appreciated!
Thanks, Bill
14 Replies 14
balaji.bandi
Hi, the first document looks really cool.
I can access the prompt ap: but need to proceed from there...
Cheers, Bill
balaji.bandi
Good to know all going as expected, let us know any further help required. if not mark as resolved please and it will be usefull for other users.
BB
Trying to reset config but still can't login at username/password...
Default cisco/cisco does not work...
balaji.bandi
you need to go reset proceedure, since its not new, it may have config.
BB
Please can you advise on break proceedure? It won't take notice of alt-b during boot...
Cheers!
press the 'ESC' key during boot, that should break the boot sequence.
break key should give you right direction. (what client you using putty or Secure CRT ?)
BB
Client mobaxterm...
balaji.bandi
hope break should work, if not reset bootloader ?
BB
Hi, I have successfully executed the 'service-module wlan-ap 0 reset bootloader' command and I''m at the ap: prompt (which I think is the equivalent of the rommon router prompt).
How do I now reset the AP configuration and the passwords to the default please??
Cheers, Bill
OK, I am *finally* into the Access Point!
I used 'service-module wlan-ap0 reset bootloader'
This got me to the ap: prompt
I then did flash_init and reset and could login to the ap with User Cisco and PW Cisco (and enable Cisco).
Cheers all...
Maybe my mistake all along was using user/pw as cisco and NOT Cisco ...
balaji.bandi
Good progress and good to know, something positive moving ...So you able to login using cisco/cisco or you having still issue
BB
