Resiliency with static mroutes
sumit_kalawatia
Hi Friends
I am trying to setup multicast over GRE tunnels between a pair of Hub routers to a spoke router. These are connected over an MPLS network that does not support multicast. The requirement is to have unicast work normally via MPLS and use CE to CE GRE tunnels only for multicast traffic. Multicast works fine when I create the GRE tunnel from the spoke to only one of the Hub routers and use a static default mroute pointing to Tunnel interface. But when I create a backup tunnel to a second Hub router, multicast is not working.
Since we can configure only one static mroute to 0.0.0.0 in Cisco IOS, I am using following workaround configuration on the Spoke router
interface Tunnel100
description To primary Hub router
ip address 100.64.0.213 255.255.255.252
ip pim sparse-mode
keepalive 2 3
tunnel source 100.64.0.211
tunnel destination 100.64.0.210
interface Tunnel200
description To secondary Hub router
ip address 100.64.0.230 255.255.255.252
ip pim sparse-mode
keepalive 2 3
tunnel source 100.64.0.225
tunnel destination 100.64.0.226
ip mroute 0.0.0.0 0.0.0.0 1.1.1.1
ip route 1.1.1.1 255.255.255.255 100.64.0.214 200
ip route 1.1.1.1 255.255.255.255 100.64.0.229 210
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 192.188.32.1 200 (192.188.32.1 is WAN IP towards MPLS cloud)
ip pim rp-address 100.64.0.209
However, when I do an RPF check for the Source or RP address, it fails.
#show ip rpf 100.64.0.209
failed, no route exists
RPF check only succeeds for the Tunnel IPs
#show ip rpf 100.64.0.214
RPF information for ? (100.64.0.214)
  RPF interface: Tunnel100
  RPF neighbor: ? (100.64.0.214) - directly connected
  RPF route/mask: 100.64.0.212/30
  RPF type: multicast (connected)
  Doing distance-preferred lookups across tables
  RPF topology: ipv4 multicast base
Need to troubleshoot why RPF is failing here.
This configuration is supposed to work as per
ftp://ftpeng.cisco.com/ipmulticast/config-notes/gre-tunnel.txt
Please advise
shivjain
hi
are you using mroute with tunnel interface as outgoing on other routers?
regards
shivlu jain
Yes Shivlu. But it does not matter since I am only looking to solve the RPF failure issue which is local to the spoke router. It is expected that  RPF check for RP address 100.64.0.209 should point to the Tunnel100 interface but it is failing instead. I also noticed some errors in the log messages of the spoke router when I do an RFP check
*Feb 13 14:27:15.296: %IPMCAST_RPF-4-RPF_LOOKUP_LOOP: RPF route lookup loop for 100.64.0.209
I can also see mpackets are coming in via Primary Hub router into the spoke but are getting dropped due to RPF check failure
*Feb 13 14:41:21.528: MFIBv4(0x0): Receive (100.64.0.218,239.192.4.130) from Tunnel100 (FS): hlen 5 prot 1 len 100 ttl 254 frag 0x0
*Feb 13 14:41:21.528: MFIBv4(0x0): Pkt (100.64.0.218,239.192.4.130) from Tunnel100 (FS) Entry IC set, punting
*Feb 13 14:41:21.528: MFIBv4(0x0): Receive (100.64.0.218,239.192.4.130) from Tunnel100 (PS): hlen 5 prot 1 len 100 ttl 254 frag 0x0
*Feb 13 14:41:21.528: MFIBv4(0x0): Pkt (100.64.0.218,239.192.4.130) from Tunnel100 (PS) Acceptance check failed - dropping
