resticting router from telnet access
sivakondalarao
I would like to how to restrict my router from telnet access from inside or outside my LAN
ankurbhasin
Level 9
Level 9
Hi Friend,
You can configure an extended access list with the sourec and destination ip whch you want to restrict and apply it on line vty as access-class command
Check this link
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fipras_r/1rfip1.htm#wp1017389
HTH, if yes please rate the post.
Ankur
pkaretnikov
I would apply the access list directly to the vty interface, as then you can use a standard or extended access list. Doing this also means that you will not slow down all traffic passing through your router(unless it's actualy a telnet to the router it's self), as acls contribute to the delay on EVERY packet they are applied to.
