Restoration of configuration backup
Rupesh Kashyap
Hi, I have one 2800 series router having inside address 10.10.10.10/24. I have configuration backup which I have taken from Putty.
In the configuration, I have many md5 encrypted key like eigrp, hsrp, bgp & ntp. I do not want to connect this in network and want to restore the configuration with all keys, how can I do it?
Ganesh Hariharan
Hi Rupesh,
Check out the belwo link for detailed step by step procedure and with different method to take backup and to restore backup for cisco router.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_tech_note09186a008020260d.shtml#tftp
Hope to help
Ganesh.H
Hi, If I will copy encrypted password of EIGRP, BGP & NTP via console which is shown in the website. Will it will work ?
Rupesh,
Genrally saying it should work because you are taking complete configuration backup of router and restoring again the same configuration to router so the size of the configuration file will be same beofre and after.so all the configigured parameters in the configuration will work once you paste the configuration.
check out the below link is the same what you are trying do !!
http://www.itsyourip.com/cisco/how-to-backup-restore-config-in-cisco-routers-and-switches-using-hyperterminal/
Hope to help
Ganesh.H
