Restoring globally cleared controller counters
wwwsteele
If counters are cleared globally on an ESR, you loose the controller tabbed history too, as shown below:
INTERVAL LCV PCV CSS SELS LES DM ES BES SES
UAS SS
16:25-16:31 0 0 0 0 0 0 0 0 0
0 0
1-Hyperion12-CHI-PE7#
Far as I know, after the clearing you only see this (15 minutes max):
UAS SS
16:32-16:44 0 0 0 0 0 0 0 0 0
0 0
That is, you only get 15 minutes UNLESS you do something to increase the length of tabbed history, such as to 24 hours. I know you can't get back what was lost, but what syntax is used to start appending data which results with the following:
INTERVAL LCV PCV CSS SELS LES DM ES BES SES UAS
SS
16:43-16:49 0 0 0 0 0 0 0 0 0 0
16:28-16:43 0 0 0 0 0 0 0 0 0 0
[Data omitted for brevity]
22:58-23:13 0 0 0 0 0 0 0 0 0 0
Total 0 0 0 0 0 0 0 0 0 0
Phoebe13-CHI-PE3#
ebreniz
Level 6
Level 6
If your are looking for the syslog servers to enable, its described in the following document.
http://www.cisco.com/en/US/products/hw/routers/ps133/products_mib_quick_reference_chapter09186a008011b360.html
