Err-disable on 3550 giga port
ifabrizio
Level 3
Level 3
Dear all,
I have one of my two giga ports on the 3550 in the following state:
C3550_Rack06#sh int gig 0/2
GigabitEthernet0/2 is down, line protocol is down (err-disabled)
Hardware is Gigabit Ethernet, address is 000e.d712.8532 (bia 000e.d712.8532)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, link type is auto, media type is SX
output flow-control is off, input flow-control is off
Last input 6d21h, output 6d21h, output hang never
Last clearing of "show interface" counters 12w0d
Queueing strategy: fifo
Output queue: 0/40 (size/max)
283555797 packets input, 2679907662 bytes, 0 no buffer
Received 141184107 broadcasts (0 multicast)
0 watchdog, 79286040 multicast, 0 pause input
116201518 packets output, 3720972769 bytes, 0 underruns
How I can determine the cause of this problem ?
Thanks & Regards
Igor.
7 Replies 7
Prashanth Krishnappa
Issue a sh log and the switch should have logged a message indicating why the port was err-disabled.
I found the message :
Mar 24 11:09:00: gbic_security_remove_gbic() gbicEntryStorage is NULL (gbic_secu
rity_unique not initialized)
I have traied to serch the meaning of this message in the "Catalyst 3550 Multilayer Switch System Message Guide" but i didn't found it.
I suppose that this message is logged when I removed and insert again the Gbic.
Try this command. show interface gi0/2 status err-disabled. It should tell you why it is in that state.
Thank you for the precious help,I do the command above and the status is :
C3550_Rack06#show interface gi0/2 status err-disabled
Port Name Status Reason
Gi0/2 err-disabled loopback
What means this status ?
Loopback means a keepalive was looped back on the interface. Check out the following bug.
http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCea46385
you can make a workaround if the port is always being diabled because of the loopback error and you dont have to shut/no shut the port.
issue the command for port autorecovey:
errdisable recovery cause loopback
errdisable recovery interval 30
neclink
it seems like excessive amount of broadcast traffic is causing the link to become disable. cheack for STP loop etc.
