Restrict Inter-VLAN routing
dan_miles86
Sorry if this is a silly question but I've read so many ariticles and gone in so many circles I'm not totally confused!
I have 3 VLAN's  (native, 40 & 50) covering across a bunch of switches being trunked back to a Cisco 2851. VLAN's 40 and 50 are configured as sub-interfaces and defined as IP Nat Inside. I then have an external internet connection which is IP NAT Outside.
All is working great however, I need to restrict routing between these internal VLAN's/subnets while stilling allowing access to the outside NAT connection.
Can anyone give me a pointer on how to do this as for security reasons I don't want these devices to be able to talk to each other.
Seb Rupik
Hi there,
The traffic betweem VLANs 40 and 50 will not be NAT'd so we don't need to worry about that.
I have made the following subnet assumptions:
VLAN40 : 10.0.40.0 /24
VLAN50: 10.0.50.0 /24
...and your bunch of switches are connected to fa0/1 , the following config should have the desired effect:
ip access-list ext v40-to-v50
  10 deny ip 10.0.40.0 0.0.0.255 10.0.50.0 0.0.0.255
  20 permit ip any any
ip access-list ext v50-to-v40
  10 deny ip 10.0.50.0 0.0.0.255 10.0.40.0 0.0.0.255
int fa0/1.40
  ip access-group v40-to-v50 in
int fa0/1.50
  ip access-group v50-to-v40 in
cheers,
Seb.
Seb Rupik
Hi there,
int fa0/1.40
int fa0/1.50
cheers,
Seb.
Thank you Seb.
I was very close but so far away! The following got it working.
ip access-list ext native
10 deny ip 192.168.30.0 0.0.0.255 192.168.31.0 0.0.0.255
11 deny ip 192.168.30.0 0.0.0.255 192.168.32.0 0.0.0.255
ip access-list ext visitor
10 deny ip 192.168.31.0 0.0.0.255 192.168.30.0 0.0.0.255
11 deny ip 192.168.31.0 0.0.0.255 192.168.32.0 0.0.0.255
ip access-list ext guest
10 deny ip 192.168.32.0 0.0.0.255 192.168.30.0 0.0.0.255
11 deny ip 192.168.32.0 0.0.0.255 192.168.31.0 0.0.0.255
!native
int g1/0
ip access-group native in
!visitor
int g1/0.1
ip access-group visitor in
!guest
int g1/0.2
ip access-group guest in
