Restrict Internet Access
cigalahgroup
        We have a small network with 30 Users and I would like to block the internet access for the 10 Users. We have DHCP running and all the network is on VLAN1, your help will be appreciated.
7 Replies 7
Seb Rupik
Hi there,
First find the MAC addresses of these 10 users and allocate them DHCP reservations from a contiguous block in the subnet.
Say you have the VLAN subnet 10.10.1.0/24, then allocate them IPs from the subnet range 10.10.1.0/28 which will give you the IPs:
10.10.1.0 -> 10.10.1.15
Then on the router interface (or SVI) for your one VLAN, place an ACL in the inbound direction:
ip access-list 100 deny ip 10.10.1.0 0.0.0.15 any
ip access-list 100 permit ip any any
int vlan1
  ip access-group 100 in
If you ever create new routed VLANs you will need to revisit the ACL, but for purely blocking internet access it will work.
cheers,
Seb.
The above configuration meant that I am blocking ips from 10.10.1.0 -> 10.10.1.15. To achieve this first I have to collect the Mac-Addresses for the know users to which I  have to block.
Can you give me the mac address binding commands as well
Is the DHCP service running on the router?
If so the command is:
sh ip dhcp server binding
cheers,
Seb.
Yes Running
To create a DHCP reservation, assuming you have a DHCP pool like this:
ip dhcp pool DHCP_VLAN01
network 10.10.1.0 255.255.255.0
domain-name domain.local
default-router 10.10.1.254
dns-server 8.8.8.8
If you have a device with a MAC address aaaa.bbbb.cccc, the client-identifer must be append with '01' and the hex shifted to the right, so aaaa.bbbb.cccc becomes 01aa.aabb.bbcc.cc
A reservation would look like this:
ip dhcp pool DHCP_VLAN01-01
  host 10.10.1.1 255.255.255.0
  client-identifier 01aa.aabb.bbcc.cc
cheers,
Seb.
Dennis Mink
alternatively put a dud proxy pac file on the 10 users machine to go direct for all internal but use a dud proxy ip  for all else.
Please remember to rate useful posts, by clicking on the stars below.
How do I achieve this
