Restricting SMTP inbound traffic
sbrown6079
I use a mail filtering service that delivers mail to me via SMTP on standard port 25 on one of my 5 static external IP's. I wish to restrict this to their IP's only (they have two) and I am unsure on how to do so? As it stands now, anything on the net can talk to my mailserver and my logs are filling quickly with failed attempts as a result. Here's my setup and what I am trying to accomplish:
mail filtering service -> my public ip:25 -> internal mailserver at 10.0.10.2:25, deny everything inbound except traffic from the mail filtering service
I am thinking an ACL would fit the bill here, but unsure of how to implement.
Router is an 1811 with version 15.1(4)M3 IOS. WAN is on fa0, lan is on fa1.
Hi Stephen,
Please correct me if I misunderstood your setup.
You want to permit only the mail service traffic from your outside (WAN) interface of your 1811 router to your inside (LAN) interface.
In this case you can create the next extended access-list
ip access list extended filter                         ->the name of the access-list
permit tcp host "public IP" host 10.0.10.2 eq 25 -> you allow only  the smtp traffic from public IP to 10.0.10.2
deny ip any any
Then you have to apply this access-list to the WAN interface
interface fa0
ip access-group filter in
Hope that helps
Vasilis
That makes sense to me, but does not appear to be working. This is what I ended up with for the ACL:
Extended IP access list smtp
    10 permit tcp host 207.210.234.37 host 10.0.10.2 eq smtp
    20 permit tcp host 207.200.28.37 host 10.0.10.2 eq smtp
    30 deny ip any any (1234 matches)
The 207.210.234.37 and 207.200.28.37 are the IP's of the mail filtering service. As a test I logged into another remote server and was able to telnet to port 25, I expected it to be denied? I also applied the ACL to fa0 inbound:
Inbound  access list is SMTP
And the only other thing I'll mention is that I have a static NAT entry for this as well (for inbound traffic):
ip nat inside source static tcp 10.0.10.2 25 my.public.ip 25 extendable
You can easily find the traffic that is denied in order to modify then you Access-list
remove the entry 30 and add the next
conf t
ip access-list extended smtp
no 30
and add the next command
100 deny ip any any log   -> 100 is the sequence number in you access-list ...should be the last entry
Then check the logs ( show logging) and you can easily find the steams that should be permited but are denied in your access-list.
Then modify your access-list according to this info.
PS: maybe you need to permit the next entries too
15 permit tcp host 207.210.234.37 eq smtp host 10.0.10.2
25 permit tcp host 207.200.28.37 eq smtp host 10.0.10.2
