Restricting specific source from registering with the RP
Umesh Shetty
Hi Experts,
I wanted to know if using the command ip pim rp-address x.x.x.x access-list  on the RP can we restrict which source can register with this RP. Most documents speak about configuring the group address for which the RP should be but can an extended ACL be called to even restrict the source from where this group traffic can be received ?
Hello
I dont think it can, that command is used with an acl is to define static pim so that IP will be the RP for specific MC groups
I think it can be negated by not having an interface PIM enabled and not statically applying the pim rp address, and If your using auto-rp then you can deifne a MC Scope or boundary.
Example:
R1<----5hops--->R6 ( R6 not to receive any Rp messages)
ip pim send-rp-discovery <interface) scope 4
or
R5
access-list 10 deny 224.0.1.40
access-list 10 permit any
int x/x
description link to R6
ip mulitcast boundary 10
res
Paul
Kind Regards
Paul
