Restrictions for PBR
jewfcb001
Level 4
Level 4
Hi everyone,
I not sure PBR(Policy base routing) has the restrictions on Cisco 6500 or not . such as IOS Image/IOS Version/SUP .
Please advise
2 Accepted Solutions
Hello
Please review the following - 6500 PBR restrictions
Kind Regards
Paul
Hello @jewfcb001
Restrictions are depended upon the various things like the IOS version you are running on 6500 and SUP engine etc. For example:
According to the below document, On Cisco IOS Release 15.0SY has the following restrictions:
Policy Based Routing (PBR) (cisco.com)
The PFC and any DFCs provide the hardware support for the following:
• These IPv4 PBR commands:
– match ip address
– match length
– set ip next-hop (2,000 instances)
– set ip default next-hop
– set interface null0
– set default interface null0
– set ip vrf
– set ip default vrf
• If the RP address falls within the range of a PBR ACL, traffic addressed to the RP is policy routed in hardware instead of being forwarded to the RP. To prevent policy routing of traffic addressed to the RP, configure PBR ACLs to deny traffic addressed to the RP.
• Local PBR.
• IPv4 PBR recursive next-hop with load balancing.
• IPv6 PBR is supported in software.
• IPv6 PBR recursive next-hop is not supported.
Note: IPv4 PBR recursive next-hop with reload balancing is not supported on Supervisor Engine 720.
Note: Local PBR does not support routing of distributed Netflow Data Export
To check the full list applicable on your IOS version click on the link below and navigate to "Configuration guides" and click on the link that applies to you.
Switches - Cisco Catalyst 6500 Series Switches - Cisco
***Please mark all helpful posts***
Spooster IT Services Team
Hello
Kind Regards
Paul
@paul driver  thank you for the answer . But  the document not tell about  image or sup etc.. for support PBR feature . but
I see the ios feature below PBR support for IP Service Image and i'm not sure my understand is it correct.
1)    IP Services--- IP Base + Full IP Routing, BGP, Policy Base Routing, GLBP, High Availability, Multi-VRF, WAN Protocols, Enhanced QOS features and Catalyst 6500 VSS.
2)    Advanced IP Services---- IP Services + ISIS, MPLS, Layer 2 VPNs, Layer 3 VPNs, IPv6.
3)    Advanced Enterprise Services---- IP Services + IPv6, Layer 3 multiprotocol like Appletalk Routing, IPX Routing, IBM Networking Services.
Hello @jewfcb001
– match ip address
– match length
– set ip vrf
• Local PBR.
