Reverse Telnet
navneet_78
What does reverse telnet refer to? Is it tht we are trying to control the functionalites of a modem through router?
Awaiting reply.
Navneet
Perhaps this will be of help:
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a008014f8e7.shtml
Quoting the URL above, "Reverse Telnet allows you to establish a Telnet connection out on the same device you telnet from, but on a different interface."
In the above example it's used on terminal servers to connect to the console ports of devices connected via async ports using the loopback interface and pre-defined ports.
Please correct me if im wrong.
6 Replies 6
navneet_78
Appreciate if someone please replies to my Query.
Thanx in advance.
Navneet
upto my knowledge that is one usage of reverse telnet to configure modems.
But maximum today all modems are auto configured by all type of routers.
skrao
Hi just to add a bit more..
Reverse telnet can be used to connect to any device which does not have a console port but it is connected to .. lets say a cisco router by a serial connection or by an internal port in the case of a IPS module on a cat 6500.
Hope it helps !!!
Thanx for the Info. It really helped.
Navneet
sayala
Reverse telnet is a feature that allows you to telnet to a Cisco device and then connect to a third device through an asynchronous serial connection; this configuration is often referred to as providing 'console server' functionality
for connected devices such as hosts and router/switches as a form of out-of-band (OOB) management. For more information on reverse telnet, consult the following documents:
http://cisco.com/en/US/products/sw/iosswrel/ps1828/products_configuration_guide_chapter09186a00800871ec.html
http://cisco.com/en/US/products/sw/iosswrel/ps1826/products_configuration_guide_chapter09186a00800d9bd8.html
