Rewrite TTL value of a packet?
d.wingert
Is there a way to rewrite the TTL value of a packet on a cisco router?
I am not asking about scoping here - I am actually searching for a way to increase the TTL value of a packet.
Regards, Dirk
sourabhagarwal
Level 4
Level 4
are you looking to increase TTL for all packets or for specific packet?
chek this URL if you get some clue.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_command_reference_chapter09186a00801a809f.html#wp1059128
rate if it helps ....
Hi Sourabh,
I need to increase the TTL of packets that I receive on one interface before they get send out another interface. Reason is that I have no way of increasing the TTL on the source.
Unfortunately, I don't think that your link provides a solution to this (the `ttl-ip` command is only for DNS related issues), but still thank you for you input!
Regards, Dirk
