RIP2 and Default Gateways
dennylester
I am following the example in the "Cisco-Configuring a Gateway of Last Resort Using IP Commands" document, but am not having much luck.
I have RIP2 working and distributing routes for the locally connected subnets but I cannot get the host to distribute it's default gateway to my remote.
Before anyone asks why I am using RIP2, I have some legacy devices out there that don't support anything else all that well..
I set the ip default-network on the host router and the show ip route command lists the proper gateway of last resort, but it never makes it to the remote.
I am sure I'm missing something simple, but can't seem to nail it down.
At the moment I don't have the host and remote in the live network. They are connected via a T1 crossover cable and a pc is attached to an Ethernet port on each router.
Any suggestions would be appreciated.
Denny
23 Replies 23
thisisshanky
Level 11
Level 11
Denny,
It would be nice to see the configs on both routers.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
The config for the host router is listed below.This router is just running the IPBase. I don't have access to the remote routers config, since I'm responding from home.
The remote router has an extremeley basic configuration as well. The only difference is it has the FW feature set. I'm not sure if this would affect this, but I wouldn't think so. These just came out of the box and I enabled a FastEthernet port and a serial port on each to play with RIP2 beforing replacing our legacy host router with this one.
I had them pinging each other via static routes to verify connectitivity, then removed the static routes and enabled RIP2.
The routing updates for each others FastEthenet subnets came across properly, I just need the host routers default gateway to transfer to the remote router.
Thank you for taking a look
Building configuration...
Current configuration : 1843 bytes
version 12.3
no service timestamps debug uptime
no service timestamps log uptime
hostname PHX2811
boot-start-marker
boot-end-marker
card type t1 0 0
no logging buffered
no aaa new-model
resource policy
network-clock-participate wic 0
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip name-server 192.168.20.17
ip name-server 192.168.20.27
no ftp-server write-enable
controller T1 0/0/0
framing esf
linecode b8zs
channel-group 1 timeslots 1-24
controller T1 0/0/1
framing esf
clock source internal
linecode b8zs
interface FastEthernet0/0
description $ETH-LAN$
ip address 192.168.4.2 255.255.255.0
duplex half
speed auto
no cdp enable
no mop enabled
interface FastEthernet0/1
no ip address
duplex auto
speed auto
no cdp enable
interface Serial0/0/0:1
no ip address
interface Serial0/0/1:1
ip unnumbered FastEthernet0/0
interface BRI1/0
no ip address
shutdown
interface BRI1/1
no ip address
shutdown
interface BRI1/2
no ip address
shutdown
interface BRI1/3
no ip address
shutdown
interface BRI1/4
no ip address
shutdown
interface BRI1/5
no ip address
shutdown
interface BRI1/6
no ip address
shutdown
interface BRI1/7
no ip address
shutdown
router rip
version 2
network 192.168.4.0
network 192.168.20.0
ip classless
ip default-network 192.168.20.0
ip route 0.0.0.0 0.0.0.0 192.168.4.1
ip route 192.168.20.0 255.255.255.0 192.168.4.1
ip http server
control-plane
scheduler allocate 20000 1000
no process cpu extended
no process cpu autoprofile hog
end
can you give a default-information originate under router rip and see if it works??
I suspect that default-information originate will work. I believe that partly Denny wants something that works, but he also wants to know why his configuration with default-network is not working. I believe that the answer is that the router is not learning the 192.168.20.0 via RIP but sees it as a local static route. If there is some classful network that the router is learning via RIP I believe that it would work as a default-network, but not a locally originated route.
Assuming that the router has a RIP neighbor on the FastEthernet 0/0 interface, if the router is learning some classful network from that neighbor, then try using that classful network as the default-network. Otherwise you probably should use default-information originate.
Rick
Rick
First I would like to thank both of you for responding.
The default gateway for this router is a Cisco Pix, which as I recall will not advertise routes, so a static is requried.
I will try the default information originate and see if that solves my problem.
Is this default-information originate supposed to be setup on the host or the remote?
I set it up on the host and the default route is still not being distributed to the remote.
Using Cisco Document ID 16448 I was able to get the remote to use the host as it's default gateway by setting the "ip default-network 192.168.4.0" on the remote. When RIP distributes the routes this seems to set the gateway of last resort to my host router.
Although this does work, it seems to go against the benefits of using a routing protocol. Should the network addressing (192.168.4.0) change, we'd have to go back and change the ip default-network on each remote to force them to use the host as their default gateway.
What we are ultimately trying to do is use floating static routes to enable DDR backup. The host will initiate all the dialing to the remotes.
Denny
The default-information originate is set up on the host. It occurs to me that it will get the host to advertise a gateway of last resort to the remote - assuming that the host has learned a default route. It might help us understand better if you would post the output of show ip route on the host router. Or if the routing table is extensive just post the header info of the display and any default route (or not) that show up in the table.
Rick
Rick
The host has a static default route. Here is show route
PHX2811#show ip rout
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.4.1 to network 0.0.0.0
C 192.168.4.0/24 is directly connected, FastEthernet0/0
S* 0.0.0.0/0 [1/0] via 192.168.4.1
PHX2811#
ruwhite
Level 7
Level 7
"I set the ip default-network on the host router and the show ip route command lists the proper gateway of last resort, but it never makes it to the remote."
Try using a default route (0.0.0.0 0.0.0.0) rather than the default-network command. First, only EIGRP and IGRP actually support the default-network, as far as propagating it through the routing protocol. Second, the default-network command is being removed from IOS at some point in the (near) future.
Russ.W
Hi Russ,
On the host router (the one that I want to advertise as the default gateway to the remotes)this is what I have and that's it..
It is not distributing this to my remote. It is distributing the 192.168.4.0 255.255.255.0 route but not the default gateway.
Perhaps I have a bugged version IOS installed..
12.3(14)T4
RIPv2 is supposed to redistribute default routes automatically.
You can turn on RIP debugging to see what your router is actually sending.
debug ip rip
or
debug ip rip event
Daniel
Yeah, I think I'm going to try a different version IOS. It really sucks when you follow the examples and it doesnt work..
As suggested, its wise to do a debug ip rip, before doing the upgrade.
Sankar Nair
I did debug ip rip and debug ip rip events and it does not appear the host router is distributing the default gateway.. I tried the IOS upgrade as well 12.14(T4) with the same results. Actually this debug output if from this latest IOS version.
Here is a snapshot of the output of debug and below that is the host routers show ip routes
192.168.23.0/24 via 0.0.0.0, metric 2, tag 0
RIP: Update contains 1 routes
RIP: Update queued
RIP: Update sent via FastEthernet0/0
RIP: received v2 update from 192.168.23.1 on Serial0/0/1:1
192.168.23.0/24 via 0.0.0.0 in 1 hops
RIP: sending v2 update to 224.0.0.9 via Serial0/0/1:1 (192.168.4.2)
RIP: build update entries
192.168.4.0/24 via 0.0.0.0, metric 1, tag 0
RIP: Update queued
RIP: Update sent via Serial0/0/1:1
RIP: sending v2 update to 224.0.0.9 via FastEthernet0/0 (192.168.4.2)
RIP: Update queued
R 192.168.23.0/24 [120/1] via 192.168.23.1, 00:00:15, Serial0/0/1:1
PHX2811#
