Role Based CLI problem
nik.sharp
I am having a problem trying to get to my root view. I am trying to set up some views to allow restricted access to one of our routers.
When I try to go to the root view, I get the following
>enable view
Password:
%  Authentication failed
I have used the enable password and the user password ( privilege level 15 user)
I am running C2800NM-ADVIPSERVICESK9-M Version 12.4(20)T as the IOS and have the following AAA entries in my config
aaa new-model
aaa authentication login default group radius local
aaa authorization network groupauthor local
aaa session-id common
I am using a radius server for login authentication. When I disable the radius server I am able to get to the root view but if I disable the radius server I stop VPN access worldwide.
Is there something I am missing here or does this function not work with a radius server?
Any help appreciated
Ivan Krimmel
Level 7
Level 7
Hi Nik,
I'd suggest you to go over this document(if haven't done so already) and let me know if it helped out:
https://supportforums.cisco.com/docs/DOC-15765
Cheers,
Ivan.
