Rommon on 5 routers
sampson01
Strange situation, we woke up to 5 of our 1941 routers, all geographically spaced by about 100 miles, all at the rommon screen and the compact flash card empty.  We already had routers on hand to replace these so we just had to speed up our replacement time table.  I now have the routers back at my office, and am trying to figure out what happened.  The CF cards do not seem bad, as I was able to reload one and get the router back up.  Thoughts, ideas on how to find out what happened?
johnlloyd_13
Level 9
Level 9
hi,
it seemed strange all 5 routers went into rommon.
could you post a show version on one of the router?
i suspect config-reg might set to 0x2142.
This is all I have until Monday, an email that sent to a colleague
System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
Copyright (c) 2011 by cisco Systems, Inc.
Total memory size = 2560 MB - On-board = 512 MB, DIMM0 = 2048 MB
CISCO1941/K9 platform with 2621440 Kbytes of main memory
Main memory is configured to 64/72(On-board/DIMM0) bit mode with ECC disabled
Readonly ROMMON initialized
program load complete, entry point: 0x80803000, size: 0x1b340
boot: cannot determine first executable file name ondevice "flash0:"
rommon 1 > ?
