Rommon
imanco671
Hello Community,
I just purchased a used ASA 5510. When I started it,  it boots into Rommon.
What should I do?
Rebooting....
Booting system, please wait...
CISCO SYSTEMS
Embedded BIOS Version 1.0(11)2 01/25/06 13:21:26.17
Low Memory: 631 KB
High Memory: 256 MB
PCI Device Table.
Bus Dev Func VendID DevID Class              Irq
00  00  00   8086   2578  Host Bridge
00  01  00   8086   2579  PCI-to-PCI Bridge
00  03  00   8086   257B  PCI-to-PCI Bridge
00  1C  00   8086   25AE  PCI-to-PCI Bridge
00  1D  00   8086   25A9  Serial Bus         11
00  1D  01   8086   25AA  Serial Bus         10
00  1D  04   8086   25AB  System
00  1D  05   8086   25AC  IRQ Controller
00  1D  07   8086   25AD  Serial Bus         9
00  1E  00   8086   244E  PCI-to-PCI Bridge
00  1F  00   8086   25A1  ISA Bridge
00  1F  02   8086   25A3  IDE Controller     11
00  1F  03   8086   25A4  Serial Bus         5
00  1F  05   8086   25A6  Audio              5
02  01  00   8086   1075  Ethernet           11
03  01  00   177D   0003  Encrypt/Decrypt    9
03  02  00   8086   1079  Ethernet           9
03  02  01   8086   1079  Ethernet           9
03  03  00   8086   1079  Ethernet           9
03  03  01   8086   1079  Ethernet           9
04  02  00   8086   1209  Ethernet           11
04  03  00   8086   1209  Ethernet           5
Evaluating BIOS Options ...
Launch BIOS Extension to setup ROMMON
Cisco Systems ROMMON Version (1.0(11)2) #0: Thu Jan 26 10:43:08 PST 2006
Platform ASA5510
Management0/0
Ethernet auto negotiation timed out.
Interface-4 Link Not Established (check cable).
Default Interface number-4 Not Up
Use ? for help.
rommon #0>
John
In config mode do this -
ciscoasa(config)# config-register 0x1
then save your config and reboot.
Jon
11 Replies 11
imanco671
I have actually booted using: boot asa804-28-k8.bin
But it keeps rebooting into Rommon,
Still researching.....
John
Can you post output of "sh version" or "sh running-config version" from your ASA when it is up and running.
Jon
Hi John,
Here is my sh ver.
ciscoasa> sh ver
Cisco Adaptive Security Appliance Software Version 8.0(4)28
Device Manager Version 6.1(5)
Compiled on Wed 18-Mar-09 17:25 by builders
System image file is "disk0:/asa804-28-k8.bin"
Config file at boot was "startup-config"
ciscoasa up 8 secs
Hardware:   ASA5510, 256 MB RAM, CPU Pentium 4 Celeron 1600 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash M50FW080 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
                             Boot microcode   :  CN1000-MC-BOOT-2.00
                             SSL/IKE microcode:  CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode  :  CNlite-MC-IPSECm-MAIN-2.05
0: Ext: Ethernet0/0         : address is 001f.9e3c.7da8, irq 9
1: Ext: Ethernet0/1         : address is 001f.9e3c.7da9, irq 9
2: Ext: Ethernet0/2         : address is 001f.9e3c.7daa, irq 9
3: Ext: Ethernet0/3         : address is 001f.9e3c.7dab, irq 9
4: Ext: Management0/0       : address is 001f.9e3c.7da7, irq 11
5: Int: Not used            : irq 11
6: Int: Not used            : irq 5
Licensed features for this platform:
Maximum Physical Interfaces  : Unlimited
Maximum VLANs                : 50
Inside Hosts                 : Unlimited
Failover                     : Disabled
VPN-DES                      : Enabled
VPN-3DES-AES                 : Enabled
Security Contexts            : 0
GTP/GPRS                     : Disabled
VPN Peers                    : 250
WebVPN Peers                 : 2
AnyConnect for Mobile        : Disabled
AnyConnect for Linksys phone : Disabled
Advanced Endpoint Assessment : Disabled
UC Proxy Sessions            : 2
This platform has a Base license.
Serial Number: JMX1215L1WW
Running Activation Key: 0x6f387d77 0xc09ded19 0xd8321914 0x98c0a8b4 0xc531adb1
Configuration register is 0x2142
Configuration has not been modified since last system restart.
ciscoasa>
John
Jon
Worked, but I am getting a username and password prompt. I have no idea what default username and password to use..
Hi Jon,
look below.
John
  ****************************** Warning *******************************
  This product contains cryptographic features and is
  subject to United States and local country laws
  governing, import, export, transfer, and use.
  Delivery of Cisco cryptographic products does not
  imply third-party authority to import, export,
  distribute, or use encryption. Importers, exporters,
  distributors and users are responsible for compliance
  with U.S. and local country laws. By using this
  product you agree to comply with applicable laws and
  regulations. If you are unable to comply with U.S.
  and local laws, return the enclosed items immediately.
  A summary of U.S. laws governing Cisco cryptographic
  products may be found at:
  If you require further assistance please contact us by
  sending email to export@cisco.com.
  ******************************* Warning *******************************
Copyright (c) 1996-2008 by Cisco Systems, Inc.
                Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
                Cisco Systems, Inc.
                170 West Tasman Drive
                San Jose, California 95134-1706
....WARNING: interface Management0/0 security level is 10.
*** Output from config line 186, "logging host management ..."
Cryptochecksum (unchanged): 51b49586 fa35f680 805cfd6b d411a9d7
Username:
So you haven't configured a username or password ?
If not try a combination of "cisco/cisco"  or "cisco/ (as in press enter key)
Jon
Also try just hitting "enter" for both username and password.
Jon
Hi Jon,
Neither worked. I think I have to reset the username and password somehow.
Is this a good guide to follow?
John
John
My apologies. I have just reread your original question and realised it was a used ASA you bought and not an original one so it may be that the previous owner setup a username/password.
So you need to a password recovery procedure to boot up the ASA without it's current config and then enter your own username/password so you can then login. See this link for details -
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/admin_trouble.html#wp1049302
Note after doing this recovery proedure you then need to set the config register back to 0x1 for it to boot automatically.
Alternatively if you are still in touch with the seller then he/she may be able to provide username/password.
Jon
@jon.marshall
Thank you for your solution, i encountered the same problem and this solution worked peerfectly.
