rommon
yoyo_the_king
hi,
i have a switch 4500.
if i extinguich and light it, he give me Rommon and i must do "boot".
how can'i resolve this.
8 Replies 8
mohammedmahmoud
Level 11
Level 11
Please make sure that the config-register is set correctly:
config-register 0x2102
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
yes i m also do config-registre 0x2102.
but without result.
chris.lepa
Also,
boot flash:
Make sure you are booting the correct image.
-Chris
hi,
how can i know image name plz.
I agree with Chris, can you provide us with "dir /all" and the boot statement you are using if any, and "show version" please.
HTH,
Mohammed Mahmoud.
this is the result of dir /all
switch#dir /all
Directory of bootflash:/
1 -rwx 12535060 Mar 12 2007 05:15:53 +00:00 cat4000-i9s-mz.122-25.EWA8
.bin
2 -rw- 10160512 Mar 12 2007 05:16:51 +00:00 k2diags.5-2.bin
27262976 bytes total (4567148 bytes free)
Are you using any boot statements ?
BR,
Mohammed Mahmoud.
i think i must do:
boot system flash:cat4000-i9s-mz.122-25.EWA8
.bin
right?
