Route all traffic over DMVPN from Spoke to Hub and out ASA FW
ciscosupportMBI
All:
Here is my scenario:
MainSite (DMVPN HUB)- Cisco 2901 - Internal IP - 10.10.20.2
MainSite (Firewall) - Cisco ASA 5525x - Inside IP - 10.10.20.253
Remote Site (DMVPN SPOKE)- Cisco 881 - Inside IP - 10.10.186.1
I want all traffic from the Remote site (including internet traffic) to route through to the Main site and out the ASA for internet access. We have a passive Web Filter at the main site and we need to capture all DMVPN remote site's traffic. We do have an MPLS for a majority of our sites, but about a dozen DMVPN's still exist.
We use EIGRP as our routing protocol.
I have a Core Switch at the Main Site that all servers/devices have their default-gateway set to. IP of 10.10.20.1. It's route of last resort is the ASA Firewall - 10.10.20.253
I have attempted a policy based route map to tag all interesting traffic and set a net-hop route, which does result in the route-map counter to tick up, but internet traffic is still going out the remote sites ISP.
VPN tunnels are up and all internal routing is working well. I've scoured the interweb and haven't found a solution to my question. So I'm hoping someone much more experienced then I at this Cisco Stuff (I'm at best at the CCNA level) can help. Config examples extremely appreciated.
THANKS!!!
Here are the configs for 2 routers: (I'm assuming we don't need the ASA involved here)
SPOKE:
BO-LAB-RTR1#sh run
Building configuration...
Current configuration : 6594 bytes
! Last configuration change at 22:02:20 UTC Tue Mar 24 2015 by admin
! NVRAM config last updated at 19:47:01 UTC Tue Mar 24 2015 by brianb
version 15.0
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname BO-LAB-RTR1
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 4096
no logging console
aaa new-model
aaa authentication login local_authen local
aaa authorization exec local_author local
aaa session-id common
memory-size iomem 10
crypto pki trustpoint TP-self-signed-220850891
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-220850891
 revocation-check none
 rsakeypair TP-self-signed-220850891
crypto pki certificate chain TP-self-signed-220850891
 certificate self-signed 01
         quit
ip source-route
ip cef
no ip bootp server
no ip domain lookup
ip domain name mobasin.local
ip port-map user-meraki port udp 7734 7351 7752 description Meraki Cloud comms
ip port-map user-p8443 port tcp 8443 description bcbsnd website
ip port-map user-RDP port tcp 3389 description RDP
ip inspect log drop-pkt
ip inspect name fw realaudio
ip inspect name fw streamworks
ip inspect name fw ssh
ip inspect name fw ftp
ip inspect name fw icmp
ip inspect name fw http
ip inspect name fw https
ip inspect name fw user-meraki
ip inspect name fw user-RDP
ip inspect name fw user-p8443
no ipv6 cef
license udi pid CISCO881-SEC-K9 sn FTX161983RT
ip tcp synwait-time 10
crypto isakmp policy 1
 encr aes
 authentication pre-share
 group 2
crypto isakmp key fun2run address 0.0.0.0 0.0.0.0
crypto ipsec transform-set DMVPN esp-aes esp-sha-hmac
 mode transport
crypto ipsec profile DMVPN
 set transform-set DMVPN
interface Tunnel0
 description dmvpn-fargodcn
 bandwidth 1000
 ip address 10.254.100.186 255.255.255.0
 no ip redirects
 ip mtu 1400
 ip nhrp authentication XXXXXXX
 ip nhrp map 10.254.100.1 66.97.245.106
 ip nhrp map multicast xxx.xxx.245.106
 ip nhrp network-id 100000
 ip nhrp holdtime 360
 ip nhrp nhs 10.254.100.1
 ip tcp adjust-mss 1360
 delay 1100
 tunnel source FastEthernet4
 tunnel mode gre multipoint
 tunnel key 100000
 tunnel protection ipsec profile DMVPN shared
interface Null0
 no ip unreachables
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
 description $ETH-LAN$$FW_OUTSIDE$
 ip address dhcp
 ip access-group outside_acl_in in
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat outside
 ip inspect fw out
 ip virtual-reassembly
 duplex auto
 speed auto
interface Vlan1
 description TestLAN
 ip address 10.10.186.1 255.255.255.0
 ip access-group inside_acl_in in
 ip helper-address 10.10.20.30
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat inside
 ip tcp adjust-mss 1452
 ip policy route-map vpn
router eigrp 100
 network 10.10.186.0 0.0.0.255
 network 10.254.100.0 0.0.0.255
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 1000
ip nat inside source list 105 interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 dhcp
ip access-list extended inside_acl_in
 deny   ip 72.20.74.0 0.0.0.63 any
 deny   ip host 255.255.255.255 any
 deny   ip 127.0.0.0 0.255.255.255 any
 permit ip any any
ip access-list extended outside_acl_in
 permit udp any any eq bootpc
 permit udp any any eq non500-isakmp
 permit udp any any eq isakmp
 permit gre any any
 permit esp any any
 permit icmp any any echo-reply
 permit icmp any any time-exceeded
 permit icmp any any unreachable
 permit tcp any any eq 22
 deny   ip 10.0.0.0 0.255.255.255 any
 deny   ip 172.16.0.0 0.15.255.255 any
 deny   ip 192.168.0.0 0.0.255.255 any
 deny   ip host 0.0.0.0 any
 deny   ip any any log
access-list 104 permit ip 10.10.186.0 0.0.0.255 any
access-list 105 deny   ip 10.10.186.0 0.0.0.255 10.10.0.0 0.0.255.255
access-list 105 permit ip 10.10.186.0 0.0.0.255 any
no cdp run
route-map vpn permit 10
 match ip address 105
set ip next-hop 10.10.20.1
HUB
rtr-far-dcn-2901#sh run
Current configuration : 8380 bytes
! Last configuration change at 15:01:00 Denver Tue Mar 24 2015 by brianb
version 15.2
no service pad
hostname rtr-far-dcn-2901
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.152-4.M2.bin
boot-end-marker
aaa new-model
clock timezone Denver -6 0
clock summer-time Chicago date Apr 6 2003 2:00 Oct 26 2003 2:00
no ip source-route
ip cef
no ip bootp server
ip domain name mobasin.com
ip inspect name fw dns
ip inspect name fw smtp max-data 4294967295
ip inspect name fw ntp
ip inspect name fw imap
ip inspect name fw imaps
ip inspect name fw pop3
ip inspect name fw pop3s
ip inspect name fw tcp
ip inspect name fw udp
no ipv6 cef
parameter-map type inspect global
 log dropped-packets enable
crypto pki trustpoint TP-self-signed-1061911734
 subject-name cn=IOS-Self-Signed-Certificate-1061911734
 rsakeypair TP-self-signed-1061911734
crypto pki certificate chain TP-self-signed-1061911734
  quit
redundancy
no ip ftp passive
ip ssh version 2
csdb tcp synwait-time 30
csdb tcp idle-time 3600
csdb tcp finwait-time 5
csdb tcp reassembly max-memory 1024
csdb tcp reassembly max-queue-length 16
csdb udp idle-time 30
csdb icmp idle-time 10
csdb session max-session 65535
 encr aes
 group 2
crypto isakmp policy 2
 encr 3des
 group 2
crypto isakmp policy 3
 group 2
crypto isakmp policy 4
 encr 3des
 group 2
crypto isakmp policy 5
 hash md5
 group 2
crypto ipsec transform-set ESP-AES128-SHA esp-aes esp-sha-hmac
 mode transport
 set transform-set ESP-AES128-SHA
interface Tunnel0
 description vpn - Fargo hub
 bandwidth 1000
 ip address 10.254.100.1 255.255.255.0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip mtu 1400
 no ip next-hop-self eigrp 100
 ip flow ingress
 ip nhrp map multicast dynamic
 ip policy route-map vpn-internet
 delay 1000
 tunnel source GigabitEthernet0/1
 tunnel key 100000
interface Null0
 no ip unreachables
interface Embedded-Service-Engine0/0
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 shutdown
interface GigabitEthernet0/0
 description lan - fargo dmvpn gateway
 ip address 10.10.20.2 255.255.255.0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat inside
 ip virtual-reassembly in
 duplex auto
 speed auto
 no mop enabled
interface GigabitEthernet0/1
 description wan - fargo dmvpn gateway
 ip address XXX.XXX.245.106 255.255.255.240
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat outside
 ip inspect fw out
 duplex auto
 speed auto
interface FastEthernet0/0/0
 no ip address
 shutdown
interface FastEthernet0/0/1
 no ip address
 shutdown
interface FastEthernet0/0/2
 no ip address
 shutdown
interface FastEthernet0/0/3
 no ip address
 shutdown
interface Virtual-Template1
 ip unnumbered GigabitEthernet0/1
interface Vlan1
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
router eigrp 100
 network 10.10.0.0 0.0.255.255
ip http server
ip http timeout-policy idle 60 life 86400 requests 10000
ip flow-top-talkers
 top 10
 sort-by bytes
ip nat inside source route-map internet interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 XXX.XXX.245.110
ip access-list extended dmvpn-traffic
 permit ip any any
 permit udp any host XXX.XXX.245.106 eq non500-isakmp
 permit udp any host XXX.XXX.245.106 eq isakmp
 permit gre any host XXX.XXX.245.106
 permit esp any host XXX.XXX.245.106
 permit icmp any host XXX.XXX.245.106 echo-reply
 permit icmp any host XXX.XXX.245.106 time-exceeded
 permit icmp any host XXX.XXX.245.106 unreachable
 permit tcp any host XXX.XXX.245.106 eq 22 log
 deny   ip any any log
no logging trap
access-list 104 permit ip 10.10.20.0 0.0.0.255 any
access-list 104 permit ip 10.10.16.0 0.0.0.255 any
access-list 104 permit ip 10.10.15.0 0.0.0.255 any
no cdp run
route-map internet permit 1
 match ip address 104
route-map vpn-internet permit 10
 match ip address dmvpn-traffic
 set ip next-hop 10.10.20.253
2 Accepted Solutions
If you can ping or traceroute to the ISP router in the main office then I can't see why it wouldn't go out to the internet.
The ASA must be translating your private IP to a public one for the ISP to be able to return the traffic.
Are you sure it is getting as far as the ISP router ?
Jon
JOHN VOLTER
9 Replies 9
Jon Marshall
I'm not sure using PBR is the right solution.
What you can do is create a VRF and put your LAN and tunnel interfaces into the VRF and then pass  a default route from the hub via EIGRP.
The router will still use the default route in the global routing table to build the tunnel over the internet but your clients at the spoke site will use the VRF default route pointing back to the hub.
See this thread for configuration details -
https://supportforums.cisco.com/discussion/12319916/dmvpn-default-gateway-issue
Jon
Thanks for the assistance Jon,
I got it a bit further with the article you shared. WIth some additional tweeking of the config in the example I now can ping the ISPs router. when doing a tracert from a client,  I also see every hop along the way (execpt the ASA). I just can't see to get it to ping 8.8.8.8 even though from everywhere else on the network I can.  I can ping the vlan interface and workstation on that router from the ASA, so I know routing is working (or so it seems) and I'm traversing the ASA when getting to the ISP router.
Here's the config I came up with to get me this far. This is on the Spoke. I've made no changes other then to back out any policy maps or Access-lists referring to the spoke on the HUB.
Any additional Help Appreciated.
version 15.0
no service pad
boot-start-marker
boot-end-marker
aaa new-model
no ip source-route
ip vrf VRF_LAN
ip cef
no ip bootp server
no ip domain lookup
no ipv6 cef
 encr aes
 group 2
 mode transport
interface Tunnel0
 bandwidth 1000
 ip vrf forwarding VRF_LAN
 no ip redirects
 ip mtu 1400
 ip nhrp authentication D1M2VPN!
 ip nhrp map 10.254.100.1 XXX.XXX.245.106
 ip nhrp map multicast XXX.XXX.245.106
 delay 1100
 tunnel key 100000
interface Tunnel1
 description dmvpn-Bismarckdcn
 bandwidth 1000
 ip address 10.254.101.186 255.255.255.0
 no ip redirects
 ip mtu 1400
 ip nhrp map multicast XXX.XXX.245.90
 ip nhrp map 10.254.101.1 XXX.XXX.245.90
 ip nhrp network-id 100001
 ip nhrp nhs 10.254.101.1
 delay 1100
 shutdown
 tunnel key 100001
interface Null0
 no ip unreachables
 switchport access vlan 186
 ip address dhcp
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat outside
 ip inspect fw out
 duplex auto
 speed auto
interface Vlan1
 no ip address
interface Vlan186
router eigrp 1
 address-family ipv4 vrf VRF_LAN autonomous-system 100
  network 10.254.101.0 0.0.0.255
  eigrp router-id 10.254.100.186
 exit-address-family
 passive-interface default
 no passive-interface Tunnel0
ip http server
ip route vrf VRF_LAN 0.0.0.0 0.0.0.0 10.10.20.1
 permit gre any any
 permit esp any any
 deny   ip any any log
no cdp run
Jon
Yup... Here's the catch, I couldn't get that far until i put in
no ip source-route
It was enabled in the original config. Once I removed that I could ping the ISP router, but still not past that.
I've also opened a TAC case to see if they can determine what else I'm missing along my path.
One article I was reading had the VRF setup on both sides of the Tunnel (hub and spoke), is that maybe something I'm missing?
Thanks!
Brian
Brian
You should need the hub to be in the VRF if you don't need it to be.
So does a "sh ip route" on the spoke show the public subnet reachable via the hub router ?
Jon
Hello Jon,
Looking closer at the hub we realized routes were pointing towards the ISP, instead of pointing to the 3850 so traffic could get to the firewall.  Once the appropriate route was added, it started working.
Have a good day :)
Also, If I remove the vrf default route, I can still ping it. I'm thinking because since the ASA participates in the eigrp neighborhood and has redistribute static it can see it's distributing the public subnet.
And when i put the "global" parameter after the route statement, and do a "sh ip route vrf *" the vrf table no longer has the gateway of last resort listed.
Ok.. The above config on the Spoke is the Correct Config. The problem was the default route on the Hub. It was leftover from when that router was still the core router for the organization and it had 0.0.0.0 0.0.0.0 pointing to the ISP router instead of my inside Core Switch. So when the packets were destined for anything other than what EIGRP knew about it would time out trying to send it out with no PAT to get back in.
Once I changed the default route to the core switch, the packets were happy!
Thanks again for the assistance!
JOHN VOLTER
Hello ciscosupportmbi
Have you looked at the front door VRF design? (fVRF)
https://www.google.com/#q=cisco+dmvpn+front+door+vrf
