Route guest v-lan out of secondary ip on single WAN port of a Cisco 2921
Damian Albury
I am currently trying to route the guest v-lan through the ISP's second public IP. There are 2 public IP's in the same sub-net with the same gateway coming on a single cable to the wan port of the Cisco 2921. I am trying to show guest traffic as originating from the secondary IP. Can anyone point me to a way to accomplish this ?
I supposed you are using NAT since you only have two public addresses. You can specify the Guest-vlan source in an access-list and create a pool with your secondry public address.
(This is only pseudo code)
access-list 1 permit 172.16.1.0 0.0.0.255 (your guest VLAN)
ip nat pool  [name] (your secondry IP) (your secondry IP)
Ip nat inside source 1 pool [name] overload
I hope I understood your question correctly.
Masoud
