Tips to change circuit router
ohforce55
I'm planning to change the Internet circuit router soon.
This is going to be the first time to do this all by myself :)
I will very appreciate if you can tell me the steps to change the router.
I don't think it is enough just to copy old config and paste it to new router...
Can you please tell me what I have to do before and after?
Thank you!
Dennis Mink
Can you tell us what you currently have and what you will replace it with?
is it just a hardware swap?  so no change in for instance IP addresses?
when you answer this, we will be able to tell you if you can copy/paste your existing config onto the new router
Please rate if helpful
Please remember to rate useful posts, by clicking on the stars below.
