ROUTE LEAK between a VRF and EIGRP GRT
titusroz03
Dear All,
I am having a Guest VRF and Eigrp configured as globally in a single router. I want to import or redistribute the static routes in the GUEST VRF into eigrp and eigrp routes should be exported to guest vrf. Do someone have a similair config for this or need help on the appropriate commands
Hello
@titusroz03 wrote:
Can someone help me to make All the routes in both the GRT and VRFS should be reachable.
no ip route vrf AV 172.16.0.0 255.255.255.0 Serial1/0
no ip route vrf AV 192.168.1.0 255.255.255.0 192.168.0.2
ip route vrf AV 0.0.0.0 0.0.0.0 Serial1/0 172.16.0.x global
router eigrp xx
redistribute static
Kind Regards
Paul
5 Replies 5
MHM
titusroz03
I configured a LAB based on the above requirement, My guest VRF is mentioned as AV and GRT is configured under eigrp. I want to leak the AV vrf routes to Global so the Users in GRT can access to AV networks.
OFFRTR#sh ip route vr
OFFRTR#sh ip route vrf AV
Routing Table: AV
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
+ - replicated route, % - next hop override
Gateway of last resort is not set
172.16.0.0/24 is subnetted, 1 subnets
S 172.16.0.0 is directly connected, Serial1/0
192.168.0.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.0.0/24 is directly connected, Serial1/1
L 192.168.0.1/32 is directly connected, Serial1/1
S 192.168.1.0/24 [1/0] via 192.168.0.2
OFFRTR#sh ip route
10.0.0.0/24 is subnetted, 1 subnets
D 10.200.2.0 [90/2172416] via 172.16.0.1, 04:12:19, Serial1/0 - EIGRP Learned route
172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 172.16.0.0/30 is directly connected, Serial1/0
L 172.16.0.2/32 is directly connected, Serial1/0
S 192.168.0.0/24 is directly connected, Serial1/1
OFFRTR#sh ip int brief
FastEthernet0/0 unassigned YES NVRAM administratively down down
Serial1/0 172.16.0.2 YES NVRAM up up
Serial1/1 192.168.0.1 YES NVRAM up up
Serial1/2 unassigned YES NVRAM administratively down down
Serial1/3 unassigned YES NVRAM administratively down down
Serial1/4 unassigned YES NVRAM administratively down down
Serial1/5 unassigned YES NVRAM administratively down down
Serial1/6 unassigned YES NVRAM administratively down down
Serial1/7 unassigned YES NVRAM administratively down down
OFFRTR#sh run | i route
router eigrp 100
ip route 192.168.0.0 255.255.255.0 Serial1/1
I have a static routes for AV and GRT networks pointing to the respective interfaces.But still I can only ping the connected interfaces but not the networks learned.
For ex:
OFFRTR#ping 192.168.0.1 source Serial1/0
Sending 5, 100-byte ICMP Echos to 192.168.0.1, timeout is 2 seconds:
Packet sent with a source address of 172.16.0.2
Success rate is 100 percent (5/5), round-trip min/avg/max = 48/61/68 ms
OFFRTR#ping 192.168.0.2 source Serial1/0
Sending 5, 100-byte ICMP Echos to 192.168.0.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
And from VRF I can ping the connected ..
OFFRTR#ping vrf AV 172.16.0.2
Sending 5, 100-byte ICMP Echos to 172.16.0.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 48/56/64 ms
But not the connected.
OFFRTR#ping vrf AV 172.16.0.1
Sending 5, 100-byte ICMP Echos to 172.16.0.1, timeout is 2 seconds:
OFFRTR#
MHM
Hello
router eigrp xx
redistribute static
Kind Regards
Paul
titusroz03
@paul driver Thanks ..I was able to reach the networks in both the VRF and GRT.Remote machines end to end reachablity is fine.
