Route Map and Static NAT
hwongnc4inc
Hi everyone,
I have a site where my main ISP is providing a 10M ethernet drop.  The site also has a 10M dsl line as a backup.  The main ISP has assigned me 3.3.3.0/26 for me to use as the ethernet drop itself is a /30.  I'm having some problems with a static NAT.  As you can see from my config, I'm doing PBR which seems to work fine.  The problem is when my box at 10.1.0.5 goes out, it's being NAT'ed as the IP from the NAT pool, 3.3.3.2 instead of the static NAT, 3.3.3.3.  I see the static NAT in the NAT translation table, but it's not being used.
I have this working at one of my other sites, but the difference is that the main ISP's ethernet drop is a /28, so I'm able to use static IPs from that same block without any issues.
This problem seems to be a NAT issue with the routed IP block.  What am I missing?
hw
Portion of my config:
track 101 ip sla 1 reachability
delay down 15 up 30
track 102 ip sla 2 reachability
delay down 15 up 30
interface FastEthernet8
description ISP1
ip address 1.1.1.2 255.255.255.252
ip nat outside
interface Vlan2
description ISP2
ip address 2.2.2.2 255.255.255.248
ip nat outside
interface Vlan5
ip address 172.18.0.1 255.255.255.248
ip nat inside
ip policy route-map PBR
ip route 0.0.0.0 0.0.0.0 1.1.1.1 track 101
ip route 0.0.0.0 0.0.0.0 2.2.2.1 100 track 102
ip route 10.1.0.0 255.255.255.0 172.18.0.2
ip nat pool NAT-OUT 3.3.3.2 3.3.3.2 netmask 255.255.255.192
ip nat inside source route-map ISP1 pool NAT-OUT overload
ip nat inside source route-map ISP2 interface Vlan2 overload
ip nat inside source static 10.1.0.5 3.3.3.3 route-map ISP1 extendable
ip access-list extended nat-list
permit ip 10.1.0.0 0.0.0.255 any
ip sla 1
icmp-echo 4.2.2.2 source-interface FastEthernet8
timeout 500
frequency 10
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 8.8.8.8 source-interface Vlan2
timeout 500
frequency 10
ip sla schedule 2 life forever start-time now
route-map PBR permit 10
match ip address nat-list
set ip next-hop verify-availability 1.1.1.1 1 track 101
route-map PBR permit 20
set ip next-hop verify-availability 2.2.2.1 1 track 102
route-map ISP2 permit 10
match interface Vlan2
route-map ISP1 permit 10
match interface FastEthernet8
ammahend
can you paste :
show ip nat translation (with primary interface active)
show ip nat translation (with backup interface active)
show ver | in image
Thank you
Ambuj
-hope this helps-
