Copy flash TFTP Error (timed out) - solarwinds
terrelstinnett
I am trying to copy my IOS to my pc using Solarwinds.
Solarwinds is Started.
I am able to ping from my pc to the fa0/1 port on my switch.
These are in the same subnet.
Pinging 192.168.1.100 with 32 bytes of data:
Reply from 192.168.1.100: bytes=32 time<1ms TTL=255
Reply from 192.168.1.100: bytes=32 time=2ms TTL=255
Ping statistics for 192.168.1.100:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 0ms, Maximum = 2ms, Average = 0ms
Switch(config-if)#do ping 192.168.1.50
Sending 5, 100-byte ICMP Echos to 192.168.1.50, timeout is 2 seconds:
Here is the error...
Switch#copy flash tftp
Source filename []? c3550-ipbasek9-mz.122-25.SEB4.bin
Address or name of remote host []? 192.168.1.50
Destination filename [c3550-ipbasek9-mz.122-25.SEB4.bin]?
%Error opening tftp://192.168.1.50/c3550-ipbasek9-mz.122-25.SEB4.bin (Timed out)
appreciate any help.
Richard Burts
Stanley
For problems like you described my first thing is to suspect a problem in IP connectivity. But your post clearly shows that IP connectivity is working ok. So we need to look for something else as the problem.
Have you used Solarwinds TFTP on your PC before to TFTP files to your PC? I am wondering if the problem might be a setting in the firewall on your PC that is not allowing the connection initiated from the switch to your PC. I have had this problem with the firewall on my PC which by default does not allow incoming TFTP connecitons.
Rick
Rick
Leo Laohoo
Duplicate post.
