Route-Map configuration
ramu.chichula
Hi all,
What is route-Map ,How we configure in Cisco routers,Pls Provide with Practical scenario,It is urgent,I am Implementing today only,Pls provide inputs
Tnks
Ramu
CMC ltd
What is the purpose you want to use route-maps for ?
Here is an example for Policy Based routing with route-map.
http://www.cisco.com/en/US/docs/ios/12_2/qos/configuration/guide/qcfpbr_ps1835_TSD_Products_Configuration_Guide_Chapter.html#wp1001019
lee.reade
Level 4
Level 4
A route-map is a very powerfull tool that can be used for a number of purposes, mainly it is used for route-filtering, when perhaps redistributing from one protocol into another, ie ospf into bgp, and you only want some of the routes to be redistributed.
You can also use the route-map to do policy based routing, which allows you to manipulate traffic flow based on source ip address example.
Additionally route-maps can also be used in NAT scenarios when you want to specificy which source ip addresses should be NAT'd.
Check out;
http://www.cisco.com/en/US/docs/ios/iproute/configuration/guide/irp_ip_prot_indep_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1056552
http://www.cisco.com/en/US/docs/ios/iproute/command/reference/irp_pi1.html#wp1015665
LR
