09-23-2022 05:49 AM
I am confused here what does the set commuity command do please, we call the same acl in the route map so am a bit confused.?
route-map RM_NCRS_TO_VM1 permit 10
match ip address ACL_NCRS_TO_VM_01
set community 28
route-map RM_NCRS_TO_VM2 permit 10
set community 29
09-24-2022 04:30 AM - edited 09-24-2022 04:34 AM
route-map RM_NCRS_TO_VM1 permit 10 <<- different route-map
route-map RM_NCRS_TO_VM2 permit 10<<- different route-map
when we need use AS-Path for specific prefix how can we do that? share the route-map you will use, if we need as-path prepend in each path?
09-24-2022 06:22 AM - edited 09-24-2022 06:23 AM
Hello @MHM Cisco World
I think it’s time for my eye test !
Apologies your absolutely correct different stanzas same acl - then if you have two ebgp peers each rm can be used to advertise a different community value using the SAME acl
09-24-2022 06:47 AM
Ohh, it happened alot for me.
I use sometimes mobile and small words or some number I dont recognize, when retrun to home use laptop I found I am totally wrong.
