Route path
Shahideachattil
I have configured ospf area 0 on all routers.R5 to R2 is lease line link
When I do the traceroute from R1 to R2 loopback address 131.131.11.98. It should be travel  through R1 to R4 to R5.
I set the traffic like this by changing ospf interface cost.
But the problem is, I have another requirement
When i do traceroute from R5 to R2 router,
The packet should be travel through R5 to R4 to R1 to R3 to R1.
I can't set the traffic like this
If i change interface ospf cost ,my first requirement is not being happened.
Is there any other way to solve this?or will i get by change cost
balaji.bandi
The packet should be travel through R5 to R4 to R1 to R3 to R1 - this is R2 i guess here
You can do different ways for the Traffic Engineering, best you can do for testing have ACL to discard that route
https://www.cisco.com/c/en/us/support/docs/ip/open-shortest-path-first-ospf/7039-1.html
if you looking full solution, post the show run config from the devices and learning routes, so we can suggest best.
BB
Duplicate post - here
Kind Regards
Paul
paul.driver
