Route reflector
ivanlopez777
I have a big issue, a route reflector is routing paths to none clients and it should not be routing paths cause it is configured as route reflector!! Help me out
Sent from Cisco Technical Support Android App
Pls elaborate having tough time in understanding your one liner statements
Ajay Raj
Your question is not clear. Please elaborate...
Make sure that on the RR peers there is the cluster-list id and verify if you are encoding the correct address families.
Remember that the route-reflector-client is on a per neighbour basis
Hth
Alessio
