route-server-client & default-originate
gusgestal
Hi All,
I'm trying to set up a lab in gns3, using route-server-client in a vrf. I'm trying to route the vrf into the global routing table in the route-server. When I apply the command "neighbor default-originate" (which works if there is no vrf) it logs the below error and tear down the bgp connection. I don't have the option of "dont-capability-negotiate" in this IOS version (if that is the issue). Any ideas of what is wrong?
In the route-server:
%BGP-3-NOTIFICATION: received from neighbor x.x.x.x/11 (invalid or corrupt AS path) 3 bytes 400200
In the route-server-client:
%BGP-3-NOTIFICATION: sent to neighbor x.x.x.x/11 (invalid or corrupt AS path) 3 bytes 400200
BGP: x.x.x.x Bad attributes
%BGP-4-MSGDUMP: unsupported or mal-formatted message received from x.x.x.x:
FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 002D 0200 0000 1540 0101 0040 0200 4003
0478 0003 0180 0404 0000 0000 00
Harold Ritter
Hi @gusgestal ,
The error message means that the BGP message is wrong because the AS PATH is empty. This is actually normal behavior, as the route server functionality is to pass updates from one client to another without inserting its own ASN. The route server is a control plane function and the router server should not be involved in the forwarding path. What you are trying to do is unsupported.
There was some bugs in the older code related to route server functionality. The newer code will not even let you inject routes from the route server to the clients.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
12 Replies 12
which images are you using in GNS3, Dynamips, or IOSv ?
It's c7200-adventerprisek9-mz.152-4.M7.bin.
can you send the configs, I'll try this on IOSv. Obviously you are aware that the versions you use are...very old.
Hi, thanks, yes, I'm aware of old version. Please see below conf:
route-server:
ip vrf internet
rd 160:50
interface GigabitEthernet0/0.50
encapsulation dot1Q 50
ip vrf forwarding internet
ip address 120.0.3.1 255.255.255.0
interface GigabitEthernet2/0
ip address 4.4.4.1 255.255.255.252
router bgp 160
address-family ipv4 vrf internet
redistribute static
neighbor 120.0.3.2 remote-as 150
neighbor 120.0.3.2 activate
neighbor 120.0.3.2 route-server-client
ip route 120.0.3.0 255.255.255.0 GigabitEthernet0/0
ip route vrf internet 0.0.0.0 0.0.0.0 GigabitEthernet2/0 4.4.4.2 global
ip vrf internet
rd 150:50
interface GigabitEthernet1/0.50
ip address 120.0.3.2 255.255.255.0
router bgp 150
redistribute static
neighbor 120.0.3.1 remote-as 160
neighbor 120.0.3.1 activate
ip route vrf internet 0.0.0.0 0.0.0.0 GigabitEthernet1/0.50 120.0.3.1
Hello
When using bgp and vrf then you need to specify address families and then within that AF advertise a default.
example:
ip vrf stan
rd 1:10
router bgp x
address-family ipv4 vrf stan
default-information originate
exit-address-family
Kind Regards
Paul
Hello, yes, I'm specifying address family, and when I applied the command "default-information originate" is when I get the errors:
R(config-router-af)#default-information originate
%BGP-3-NOTIFICATION: received from neighbor 120.0.3.2 3/11 (invalid or corrupt AS path) 3 bytes 400200
Hello
Why are you adding a static default into the vrf rib when you want it to be advertised via bgp vrf? -  in any case looks like the bgp capbailites of each neigbour are not supported, try
neighbor x.x.x.x dont-capability-negotiate
Kind Regards
Paul
Hi, because I need to route that vrf to internet (there is another router with 4.4.4.2 acting as gateway.
I don't have the option "dont-capability-negotiate" in this IOS version.
Hello
What IOS are you using and on what rtr?
Kind Regards
Paul
c7200-adventerprisek9-mz.152-4.M7.bin on both.
Harold Ritter
Hi @gusgestal ,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Thanks Harold. I think I will have to start from scracht my design then.
