Hello Rob,
>> For example, the second I ping a website, the ip address is resolved and then the route is added for the source ip address with the default gateway of the proxy server.
>> they are pushing all of the routing rules down to the workstation which is causing the local route tables to grow to be massive in a very short time.
This might be the effect of ICMP redirect messages sent from network device to PC indicating the proxy server as the gateway for each required destination
For the effects and workaround on PC side you can see
http://www.xnews.ro/QWDisable_ICMP_Redirect.htm
For an explanation on ICMP redirect on cisco routers you can read
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094702.shtml
For disabling ICMP redirects on the router internal LAN interface
configure t
interface type x/y
no ip redirects
All the PC workstations should have the proxy-server as their default gateway and not the Cisco router.
WARNING: without knowledge of your network topology it is not possible to understand if your internet access will still work after disabling ICMP redirects on the router. It should work but it is wise to consider all possibilities.
However, the first link provides a way to make a windows PC to ignore ICMP redirects and can be used to verify if the filling of the routing table on the host is caused by ICMP redirects ( likely)
If you can install a wireshark protocol analyzer on a PC you can also capture the ICMP redirect messages and you can find out what is the device sending them to your PC.
Hope to help
Giuseppe
