route voice traffic through one link and data through another
gavin han
i've a PBX system connected to the router. so want to route PBX traffic through one link while rest of the data traffic through other link. is it possible. how do i do that?
Pls advise..
Jon Marshall
Pls advise..
Gavin
Sounds like a job for PBR. Need some info before we can supply a config -
1) does the data and PBX traffic come in on the same interface on the router eg. LAN interface
2) by the sounds of it there are 2 other links on the router (WAN possibly ?) and you want voice to go down one and data the other ?
3) If there are 2 links do you have a default-route for one of the links and which link is this ie. the link for data or the link for voice ?
Jon
Hi Jon,
it is T1/E1 interface that connects to PBX. it doesnt show up in "sh ip int b" command output.
Gavin
Can't really help without answers to questions i asked other than to simply say PBR sounds like it may help.
Basically PBR is used when traffic is arriving on a certain interface and you want to send some of this traffic down one route and some of the traffic down another. From your description it's not possible to say whether this is your scenario or not.
Jon
