route
alaeldien
hello
iam having router with serial interface configured with public ip, and i have LAN with host configured with private ip address, so i want this host to be accessable form the internet, ihave configured static route in the router
Ip nat inside source static 192.168.1.22 255.255.255.0 ***.***.***.*** (our Public IP )
but it's not work
can any body please advice
Whichever one you want to. You can use either.
For simplicities sake use the free public address.
Jon
9 Replies 9
royalblues
Level 10
Level 10
You need to have the following
ip route 0.0.0.0 0.0.0.0
interface
ip nat inside
interafce
ip nat outside
Narayan
ariesc_33
it should be
Ip nat outside source static public_ip inside_ip
interface Ethernet1
ip address *********
ip nat inside
interface Serial1
ip nat outside
now tell me which one is correct ;)
Narayan's solution is correct - it is an "ip nat inside ..." statement that is needed.
Jon
hello
yes Narayan is seem to be right, but how to determine next-hop-address ?!!!!
the other solution provided ,seem to be and it's really will stop the access to the Router from the host.
The next-hop ip address should be the IP address on the other end of your serial link. So you have a public IP on your end - do you know what the IP on the other end is.
Alternatively you could just point the default-route out of your serial interface eg.
ip route 0.0.0.0 0.0.0.0 serial0
where serial0 is the serial interface on your router. It would be more efficient though if you could use the next-hop IP address if you can.
Jon
hello
i have public ip address asigned to serial ineterface along with other FREE PUBLIC ip address from ISP , which one we have to use
in the public ip address fields
ip nat inside source static 192.168.1.1 *******
help please
Alaa
Jon
hello
this my second case solved in this dissc, previous one solved by Giuseppe
so thanks to all
