Router 1921 crypto issue
wajid dabir
One of my client try to configure the crypto key,but the router is not taking the command.
What can be the issue...
Router has security and data base license installed.
Router detail is attached in snap.
8 Replies 8
cadet alain
you need a security licence for IPSec VPNs, check it with show licence command.
Alain
sathvik k v
Level 3
Level 3
Hi Wajid,
If you are having security license the show version should display as below. If not license needs to be purchased. The IOS in the device is a universal image which will not have any features by default.
Technology Package License Information for Module:'c1900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      securityk9    Permanent      securityk9
data          None          None           None
Sathvik
wajid dabir
Dear cadet,
router has securityk9 license install for evaluation version.
in detail it is showing:
License type: Evaluation
License State: Active, not is use, EULA Accepted
Hi Wajid,
Refer the below URL which would help you getting the  solution.
https://supportforums.cisco.com/thread/2175438
Sathvi
Sathvik,
i am trying to solve this issue,still its in same condition.
Index 2 Feature: securityk9
        Period left: 8  weeks 4  days
        Period Used: 0  minute  0  second
        License Type: Evaluation
        License State: Active, Not in Use, EULA accepted
        License Count: Non-Counted
        License Priority: Low
Hi Wajid,
The license typr should be permanent. Please check with cisco once. You are using a Evaluation license.
        License Type: Permanent
        License State: Active, In Use
Sathvik
Issue is resolved now.the problem with license is that it was not properly install.activation procedure for evaluation is diffarent then the normal license.
after installing,to activate we need to type below command and need to reload the license.after that only the license will take effect.
license boot module C1921 technology-package securityk9
Wajid Dabir
Thanks for sharing the info
Sathvik
