Router 2811 rommon with problem in flash
iccjflores
Hello
I have a question referent at Router 2811 i can't load the ios since flash: when this start or reload, this send a message referent to not recognize the flash: and tha no contein the valid FS, this make when i want to charge the image since flash:, usb or tftpdnld -r  (whit this the router not reload when finish the load the image) and xmodem, i don't know what is the problem...
I hope that somebody can help me thank you
System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
Copyright (c) 2004 by cisco Systems, Inc.
Initializing memory for ECC
c2811 processor with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC enabled
Readonly ROMMON initialized
device does not contain a valid FS
loadprog: error - on file open
boot: cannot load "flash:c2800nm-adventerprisek9-mz.124-15.T9.bin"
boot: cannot open "flash:"
boot: cannot determine first executable file name on device "flash:"
rommon 1 >
rommon 1 > dir flash:
dir: cannot open device "flash:"
rommon 2 > dev
Devices in device table:
        id  name
    flash:  compact flash
bootflash:  boot flash
    eprom:  eprom
rommon 3 > ?
alias               set and display aliases command
boot                boot up an external process
break               set/show/clear the breakpoint
confreg             configuration register utility
cont                continue executing a downloaded image
context             display the context of a loaded image
cookie              display contents of motherboard cookie PROM in hex
dev                 list the device table
dir                 list files in file system
dis                 disassemble instruction stream
dnld                serial download a program module
frame               print out a selected stack frame
help                monitor builtin command help
history             monitor command history
iomemset            set IO memory percent
meminfo             main memory information
repeat              repeat a monitor command
reset               system reset
rommon-pref         Select ROMMON
set                 display the monitor variables
showmon             display currently selected ROM monitor
stack               produce a stack trace
sync                write monitor environment to NVRAM
sysret              print out info from last system return
tftpdnld            tftp image download
unalias             unset an alias
unset               unset a monitor variable
xmodem              x/ymodem image download
rommon 4 > cont
cont: can not continue, no system kernel context
rommon 5 > context
context: kernel context is not valid
rommon 6 > boot flash flash:c2800nm-ipbase-mz.124-3i.bin
an alternate boot helper program is not specified
(monitor variable "BOOTLDR" is not set)
and unable to determine first file in bootflash
boot: cannot load "flash flash:c2800nm-ipbase-mz.124-3i.bin"
rommon 7 >
mrdogantr
     I think your card corrupt. you can try the "tftpdnld -r" option, not to write to flash and check your flash again later than image is loaded.
hth
Muammer
ps : please rate the helpful posts.
skarthic
If you think if the problem is with the card, try a working flash card in this device to isolate the problem.
