Router 2821
KlediBodinaku24
Greetings
May someone help me in telling what kind of interface do i have to use to expand this router to be able to connect 4 different LANs.
The router only has two fastethernet ports. You will need to get a switch that supports vlan and configure inter-vlan routing or "router on a stick"
http://www.cisco.com/en/US/products/ps6545/products_configuration_example09186a00806da6c9.shtml#routing
Danilo Dy
The router ships with GE, you can choose connecting it to a switch and configure vlan trunking. You also have a choice of plugging an etherswitch network module which comes in 4 port +
else check this guide http://www.cisco.com/application/pdf/en/us/guest/products/ps5855/c1031/cdccont_0900aecd8019dc1f.pdf
