Router 2921 service module
Samar
I have erased ios from serice module of router 2921. Then i was trying to upload ios using copy xmodem: flash:(file name) But it was taking much time. At this point Console clock rate was 9600 Line vty 67 BAUD 9600 SW BAUD 9600. Then unfortunately i have used this command in swith... "set BAUD 57600" which was successful . But now i can no more access the sw becouse line vty 67 only support baud rate of 9600/115200. Now how can i change the baud rate of sw to get back in switch. in this condition.
marce1000
 - Check if this thread can be helpful :
            https://community.cisco.com/t5/network-management/cisco-2951-and-48port-etherswitch-module-baud-issues/td-p/3793607
 M.
follow the procedure for 'Recovering from a Lost or Forgotten Password When Password Recovery Is Disabled' as outlined in the document linked below. This will get you to the 'set' command and lets you change the baud rate:
https://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/software/feature/guide/eesm_sw.html#pgfId-1931640
