Router 3945 log
dbarboza27
I am getting the following message from a 3945 router:
%CERM-4-TX_BW_LIMIT: Maximum Tx Bandwidth limit of 85000 Kbps reached for Crypto functionality with securityk9 technology package license.
That router has 8 Gre/IPsec tunnels and one of those tunnels is 100Mbps.
The question is, could I get 100Mbps as the sum of all tunnels, or is there a restriction to 85Mbps ??
dumesh
Hi Douglas,
Do you have hseck9 license installed on the router?
You should not be seeing this message if you already have the hseck9 license installed.
Dheeraj
Hi Dheeraj,
That license is not installed in the router. Attached is an output from the router.
Router#sh license
Index 1 Feature: ipbasek9
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Medium
Index 2 Feature: securityk9
Index 3 Feature: uck9
        Period left: Not Activated
        Period Used: 0  minute  0  second
        License Type: EvalRightToUse
        License State: Not in Use, EULA not accepted
        License Priority: None
Index 4 Feature: datak9
Index 5 Feature: gatekeeper
Index 6 Feature: LI
Index 7 Feature: SSL_VPN
        License Count: 0/0  (In-use/Violation)
Index 8 Feature: ios-ips-update
Index 9 Feature: SNASw
Index 10 Feature: hseck9
Index 11 Feature: cme-srst
Index 12 Feature: UCVideo
