Router 4221 WebUI access failed
Hi to everyone,
I have a Cisco Router 4221.
firmware:
isr4200-universalk9_ias.17.03.02.SPA.bin
I did these commands for enable the webUI
ip dhcp pool WEBUIPool
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 192.168.1.1
username webui privilege 15 password cisco
interface gig 0/0/1
I try via browser to "https://192.168.1.1/#/dayZeroRouting" but it doesn't works.
Can someone help me?
Thank you so much
balaji.bandi
Hello
Have you enabled HTTPS secure on the rtr, if not try accessing it via HTTP://192.18.1.1 instead which used to be enabled by default.
Basic HTTPS configuration:
no ip http server
ip http authentication local
ip http secure-server
Kind Regards
Paul
Hi Paul, thank you
The issue was there:
"username webui privilege 15 password cisco"
I change with
"username cisco privilege 15 algorithm-type scrypt secret cisco"
Now it works
Thank you for supprt
Glad it was username issue becaus of securit you need to have secure password.
BB
