Router 827 - Can't get Nat working properly to webserver
dborg
Hi All
Cant seem to conenct to my webserver exteranlly. if anyone can shed some light that would be neat.
here are the debug statements:
Router#
00:27:41: NAT: s=x.x.250.234, d=x.x.245.114->192.168.1.100 [24703]
Router#
00:27:44: NAT: s=x.x.250.234, d=x.x.245.114->192.168.1.100 [24704]
Router#
00:28:44: NAT: expiring x.x.245.114 (192.168.1.100) tcp 80 (80)
here is my config
ip nat inside source list 1 interface BVI1 overload
ip nat inside source static tcp 192.168.100.10 80 x.x.245.114 80 extendable
ip classless
ip route 0.0.0.0 0.0.0.0 x.x.245.113
no ip http server
thanks Dom
jackyoung
Level 6
Level 6
Can you advise the result w/o the parameter of "extendable" in NAT statment ?
Moreover, can you try below ?
ip nat outside source static tcp x.x.245.114 80 192.168.100.10 80
And, did you confirm your web server use only TCP port 80 ? Will it also use other port ? If it still not work, try to use static NAT (w/o tcp & port no.) to test and verify it works then add the port back.
Hope this help and wait for your udpate.
Edison Ortiz
Dominic,
It seems your internal webserver IP is 192.168.1.100 but you have 192.168.100.10 as the source NAT IP.
