Hi there,
I´m having trouble connecting to the internet with the 877 router; I have tried several different configurations, but I always fail to connect. The Telecom said that the line is Ok, and in fact I´ m able to connect through the old Alice modem I have, even with a good bandwidth (6.5 Mbps in download). But when I try to use the 877, it fails. I was wondering whether it has to do with the attenuation: usually it is around 12 dB, as shown here below. But in my case it´s around 32dB. Can this be the reason ? or do I have to did deeper in my config file ?
router#sh dsl int
ATM0
Alcatel 20190 chipset information
ATU-R (DS) ATU-C (US)
Modem Status: Showtime (DMTDSL_SHOWTIME)
DSL Mode: ITU G.992.1 (G.DMT) Annex A
ITU STD NUM: 0x03 0x1
Vendor ID: 'STMI' 'TSTC'
Vendor Specific: 0x0000 0x0002
Vendor Country: 0x0F 0xB5
Capacity Used: 100% 60%
Noise Margin: 11.5 dB 23.0 dB
Output Power: 14.5 dBm 13.0 dBm
Attenuation: 12.0 dB 3.0 dB
Defect Status: None None
Last Fail Code: None
Watchdog Counter: 0xF5
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction: 0x00
Interrupts: 8093 (0 spurious)
PHY Access Err: 0
Activations: 2
LED Status: ON
LED On Time: 100
LED Off Time: 100
Init FW: init_AMR-2.6.004.bin
Operation FW: AMR-2.6.004.bin
FW Version: 2.6.4
Interleave Fast Interleave Fast
Speed (kbps): 6336 0 480 0
Cells: 126700 0 14300 0
Reed-Solomon EC: 0 0 0 0
CRC Errors: 0 0 0 0
Header Errors: 0 0 0 0
Total BER: 0E-0 0E-0Leakage Avarage BER: 0E-0 0E-0
LOM Monitoring : Disabled
DMT Bits Per Bin
000: 0 0 0 0 0 0 0 2 3 5 5 6 7 7 7 7
010: 7 7 7 7 7 7 7 6 6 6 6 5 4 3 2 0
020: 0 0 0 0 0 A A A B A A A A A A B
030: A A A A A A A A A A A A A A A A
040: 0 9 A 9 A 9 9 9 9 9 9 9 9 9 9 9
050: 9 9 9 9 9 9 9 9 9 9 8 9 9 9 9 9
060: 9 9 9 9 9 9 9 8 9 9 9 9 8 8 9 8
070: 9 9 8 2 8 8 8 8 8 8 8 8 8 8 8 8
080: 8 8 8 8 7 8 8 8 7 8 8 8 8 8 7 7
090: 8 7 7 8 8 7 7 7 7 8 8 7 7 7 7 8
0A0: 7 7 7 8 7 7 7 8 8 7 7 7 7 7 7 7
0B0: 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7
0C0: 7 7 7 6 7 7 7 7 6 7 6 7 7 7 7 7
0D0: 7 7 7 6 6 6 6 7 6 6 6 6 6 6 6 6
0E0: 6 6 6 6 6 6 6 6 7 6 7 6 6 6 6 6
0F0: 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6
DSL: Training log buffer capability is not enabled
The above output was taken from a 877 of a friend of my, who has the same contract with the Telecom.
Thanks or any comment.
