Router 891 CPU LIMIT vs Bandwith usage
ahorta001
Hi to everyone !!!
Im using Cisco routers for a while and really happy about performance and funcionalities !
What Im facing is a problem in a branchoffice that has a 891 router in the edge. This router is working fine but i think Im arriving, as grow in usage, to hardware limit. What I want to know if someone had same design usage if I need to upgrade to a better router of better series.
- WAN bandhwith 25 Mbps
- LAN switching 60 Mbps
firwalling in LAN
firewalling in WAN
dhcp server
dns
nat
IPsec tunnel in WAN with 2 Mbps of traffic
QoS in WAN
15.2 is the IOS Im using
I find this in internet that state that the 890 routers has 50 Mbps of traffic to work well
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/routerperformance.pdf
CPU usage is arriving to 90-95 % Is this ok or I can solve problem with a change of configuration? I think that IM arriving router hardware limit...
Thanks for any advice !! kind regards !!
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
For an even better look at 890 performance, see my attachment.
An 891 is undersized for you link's maximum bandwidth, but I would expect better than 2 Mbps of encrypted performance. So yes, you may have a non-optimal configuration.
Have you seen: http://www.cisco.com/c/en/us/support/docs/ip/generic-routing-encapsulation-gre/25885-pmtud-ipfrag.html ?
