router ASR 1002-X firmware update
cisconn00b
Hello I am trying to update the IOS with file asr1002x-universalk9.16.03.10.SPA.bin.  I copied it from a usb drive to the dir flash:
I am not sure on the commands to install the firmware.  I don't care for the configuration on the router, just need it to be updated.  Any tips?  Thank you all.
Mark Elsen
 - FYI : https://www.cisco.com/c/en/us/td/docs/routers/asr1000/software/configuration/xe-17/asr1000-sw-config-xe-17/issu-asr.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
