Router automatically goes to ROMMON mode
kumarpmt83
I have one problem in my Client end router cisco 1841.
Everyday we switch on the router it will automatically goes to ROMMON mode.
So i take remotly and check wheather the IOS is corrupted or not.
So i use the command dir flash: to check IOS is available or not. i found the IOS is there.But it is not boot from IOS.
So i use the coomand boot xxxx.bin to boot from IOS.and finally it booted.
i am not able to do this work everyday.
Anyone give the permanent solution.
But i search in the internet they give some steps.
They told to use the coomand confreg in the ROMMON mode.
And also i check everything fine.
Kindly give me the solution.
8 Replies 8
Leo Laohoo
In ROMmon mode, please enter the command "confreg 0x2102".
Once you have booted the router in normal mode you need to set up the boot and config register
Router(config)# boot system flash: filename
Router(config)#config-register 0x2102
Save the configuration and reload the router
It should work
Eugen
As per u advice i am tried but it again come same problem.
can u tell anyother way to solve the issue.
You said that when you use the boot command it boots in IOS ok.
While in IOS use "show version" and "show flash:" and post the output
Eugen
DSO#sh version
Cisco IOS Software, 1841 Software (C1841-ADVSECURITYK9-M), Version 12.4(11)T, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Sat 18-Nov-06 15:46 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
DSO uptime is 5 hours, 46 minutes
System image file is "flash:c1841-advsecurityk9-mz.124-11.T.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 1841 (revision 6.0) with 235520K/26624K bytes of memory.
Processor board ID FHK104615Y2
2 FastEthernet interfaces
1 Serial(sync/async) interface
1 ISDN Basic Rate interface
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
DSO#sh flash:
-#- --length-- -----date/time------ path
1     17793652 Nov 16 2006 12:12:56 +05:30 c1841-advsecurityk9-mz.124-3g.bin
2         1821 Nov 16 2006 12:29:58 +05:30 sdmconfig-18xx.cfg
3      4734464 Nov 16 2006 12:30:38 +05:30 sdm.tar
4       833024 Nov 16 2006 12:31:06 +05:30 es.tar
5      1052160 Nov 16 2006 12:31:36 +05:30 common.tar
6         1038 Nov 16 2006 12:32:02 +05:30 home.shtml
7       102400 Nov 16 2006 12:32:24 +05:30 home.tar
8       491213 Nov 16 2006 12:32:50 +05:30 128MB.sdf
9      1684577 Nov 16 2006 12:33:36 +05:30 securedesktop-ios-3.1.1.27-k9.pkg
10      398305 Nov 16 2006 12:34:10 +05:30 sslclient-win-1.1.0.154.pkg
11    22649648 Feb 22 2007 11:58:48 +05:30 c1841-advsecurityk9-mz.124-11.T.bin
14249984 bytes available (49762304 bytes used)
DSO#
Nothing wrong with your "sh ver" and "dir" output.
Can you provide the output to the command "sh run | i boot"?
May I ask if you can console into the router and reboot?  I would like to see the complete bootup process.
  I have a same issue, but it is not always. I saw that router suddenly goes to ROMmon without any reason.
I like to know whether you found the reason or solution.
Thanks for your time and effort.
Not always?  Maybe your router crashed?
