router can't resolve dns after enable ios firewall
chuang123
hi all,
my 1841 router can't resolve dns after enable ios firewall, I try to ping google.com from router's console fail, but dns resolution is fine from lan side.
what could be the cause?
my partial config---------------------------------
ip name-server 8.8.8.8
ip inspect name myfirewall tcp
ip inspect name myfirewall udp
ip inspect name myfirewall ftp
ip inspect name myfirewall icmp
ip inspect name myfirewall bootpc
ip inspect name myfirewall bootps
ip inspect name myfirewall dns
interface FastEthernet0/0
ip address 172.16.1.2 255.255.255.0
ip access-group 103 in
ip nat outside
ip inspect myfirewall out
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.2.1.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.16.1.1
ip http server
ip http authentication local
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0/0 overload
access-list 1 permit 10.2.1.0 0.0.0.255
access-list 101 permit udp any any eq bootpc
access-list 102 permit ip 10.2.1.0 0.0.0.255 any
access-list 102 permit ip host 172.16.1.2 any
access-list 103 permit tcp any any eq telnet
access-list 103 permit tcp any any eq 22
access-list 103 permit tcp any any eq www
access-list 103 permit tcp any any eq ftp
access-list 103 permit icmp any any
access-list 103 deny   ip any any
this feature appeared in 12.3(T) so it should be ok for you , can you try it in  your ip inspect myfirewall udp statement.
There is also another way of achieving this:http://blog.ine.com/tag/pbr/
Alain
10 Replies 10
cadet alain
if your IOS support this command , you can do this:
ip inspect name myfirewall dns router-traffic
otherwise you'll have to permit DNS replies in your ACL 103.
Alain
hi,
my IOS is
(C1841-ADVENTERPRISEK9-M), Version 12.4(24)T8, RELEASE SOFTWARE (fc1)
it seems doesn't support this command: router-traffic
do you know which version support this command?  appreciated for your help.
btw, if I permit DNS in ACL 103, will this to be protential DNS attack? I used to be blacklist by my ISP because they indicate that my IP is flooding DNS packet in their network.
Alain
thanks Alain!!
I have confirmed both solution works perfect!! thanks for solving my issue!!
Did you try to ping sourcing from the router's inside int?
hi, you cannot specify a source from lan interface when ping to a domain name. (I just tested, it only work with ip)
for example:
ping 8.8.8.8 source 10.2.1.1 <--- this is ok
ping yahoo.com source  <---- this sub command source will not work
So are you able to ping 8.8.8.8 from the router's outside int? Or you have same issue with domain name?
The problem was that CBAC wasn't inspecting traffic generated by the router and so there are 3 solutions:
1) use the router-traffic keyword in the ip inspect command
2) trick the router to make it see this traffic as transit traffic by using local PBR
3) add a permit statement for the return traffic in the ACL applied inbound on the WAN interface
Alain
Great answers Alain. Thank you man.
@ alain
i have rated this mate nice to know this little gem - are you able to clarify if this router-traffic command is basically a control.plane function for cbac
res
paul
Sent from Cisco Technical Support Android App
Kind Regards
Paul
