I have a 3845 edge router connected to the Internet via four T1s and a HWIC-4T1/E1 card. We are adding two more T1s to the mix, and I have a VWIC2-2MFT-T1/E1 card. Here are my questions:
1. Is it correct to state that the VWIC2-2MFT-T1/E1 can support data in addition to voice?
2. I can use the HWIC and VWIC cards together to utilize the 6 T1s together?
3. Do I just add the card, configure the new slot, and add it to the same channel group?
Below is the current config regarding the existing card HWIC:
card type t1 0 0
security authentication failure rate 3 log
security passwords min-length 6
logging message-counter syslog
logging buffered 51200
controller T1 0/0/0
cablelength long 0db
channel-group 0 timeslots 1-24
controller T1 0/0/1
controller T1 0/0/2
controller T1 0/0/3
Thanks ahead of time. I will be sure to rate.
