Router can't resolve domain names
MoMohib
Router#ping www.google.com
% Unrecognized host or address, or protocol not running.
When i ping google IP it works :
Router#ping 216.58.198.206
Sending 5, 100-byte ICMP Echos to 216.58.198.206, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 19/19/19 ms
My network architetcure :
Modem (DNS-server) <------------- Cisco Router <------------- Siwtch <----------- LAN
    192.168.1.1
My configuration :
ip name-server 192.168.1.1
ip domain name momohib.com
ip domain lookup
ip dns server
Can you please help me to figure out this issue . Thank you
6 Replies 6
nazimkha
Can you ping your DNS server from the router
Yes i can ping my dns server from the router
Router#ping 192.168.1.1
Sending 5, 100-byte ICMP Echos to 192.168.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/2 ms
remove:
ip dns server
from your configuration, as your DNS server is not the router but an external device.
Hi ,
I deleted ip dns server from the configuration, but i still have the same problem :(
Router#ping www.google.fr
Hi ,
I deleted ip dns server from the config, but i still have the same problem :(
The syntax:
ip domain lookup
looks wrong, it should be:
ip domain-lookup
