Router Certificate Question
benolyndav
Level 4
Level 4
How do I renew Router Cert do I have to go through the full Enrollment process again and define the trustpoint
or is there a command to renew the cert as the trustpoint already configured.??
that is part of CSR
BB
balaji.bandi
is local CA or Public CA ? what router and IOS Code ?
check below guide :
https://www.cisco.com/c/en/us/support/docs/security-vpn/public-key-infrastructure-pki/116094-technote-pki-00.html
BB
how do I add in the fields below the router isn't allowing me to add any info when cert enrollment ??
 cn=VPN-RTR.1.
  ou=
   o=
   c=GB
that is part of CSR
BB
