Router Command for a route to specific host or network
Faresnani
Hello Cisco Community
I have a 300 Subnet in our enterprise network and there is a complex routing table for OSPF protocol, so for faster troubleshooting of the network connectivity and routing table, I want to show is there any route for a specific subnet or a host  with a single command or maybe filtering the output of routing table
if there are any commands please replay
2 Accepted Solutions
Show ip route
Display all route table (300 subnet)
Show ip route x.x.x.x
Display the route use to forward this exactly ip (x.x.x.x)
Show ip route x.x.x.x longest-prefix
Display all route can use to forward this prefix (x.x.x.x)
Faresnani
The Solution from Command Reference https://www.cisco.com/E-Learning/bulk/public/tac/cim/cib/using_cisco_ios_software/cmdrefs/show_ip_route.htm
When you specify that you want information about a specific network displayed, more detailed statistics are shown. The following is sample output from the
show ip route
 command when entered with the address 131.119.0.0.
Router# show ip route 131.119.0.0
Routing entry for 131.119.0.0 (mask 255.255.0.0)
            Known via "igrp 109", distance 100, metric 10989
            Tag 0
            Redistributing via igrp 109
            Last update from 131.108.35.13 on TokenRing0, 0:00:58 ago
            Routing Descriptor Blocks:
            * 131.108.35.13, from 131.108.35.13, 0:00:58 ago, via TokenRing0
                        Route metric is 10989, traffic share count is 1
                        Total delay is 45130 microseconds, minimum bandwidth is 1544 Kbit
                        Reliability 255/255, minimum MTU 1500 bytes
                        Loading 2/255, Hops 4
Table 69 describes significant fields shown in the display.
Table 69: Show IP Route with Address Field Descriptions (Continued)
Field
Description
Network number and mask.
Indicates how the route was derived.
distance 100
Administrative distance of the information source.
Tag 0
Integer that is used to implement the route.
Indicates redistribution protocol.
Indicates the IP address of a router that is the next hop to the remote network and the router interface on which the last update arrived.
0:00:58 ago
Specifies the last time the route was updated in hours:minutes:seconds.
Indicates the next hop address, the address of the gateway that sent the update, and the time that has elapsed since this update was received in hours:minutes:seconds.
via TokenRing0
Interface for this route.
This value is the best metric for this routing descriptor block.
Number of uses for this routing descriptor block.
Total propagation delay in microseconds.
Minimum bandwidth encountered when transmitting data along this route.
Reliability 255/255
Likelihood of successful packet transmission expressed as a number between 0 and 255 (255 is 100 percent reliability).
Smallest MTU along the path.
Loading 2/255
Effective bandwidth of the route in kilobits per second/255 is saturation.
Hops 4
Hops to the destination or to the router where the route first enters IGRP.
5 Replies 5
Richard Burts
I do not believe that there is any single command or any filtering of the output of the routing table that will give you what you want. When forwarding an IP packet the logic for searching the routing table is complex, starting with looking for a /32 specific match and successively looking for less specific matches (is there a /28 subnet that matches, is there a /24 network that matches, is there a /16 that matches, is there a /0 that matches). I do not know of any single command that could give you that answer.
Rick
Thank you for your reply, I actually tried this way first and I saw this as not an ideal way to find the route to a network from 300 subnets, and it may be a bit stressful and I may make mistakes.
Faresnani
Show ip route
Thank you for your reply and it was really helpful and handy to minimize the probabilities and make it easier too thanks
Faresnani
Faresnani
show ip route
            Tag 0
Field
Description
distance 100
Tag 0
0:00:58 ago
via TokenRing0
Reliability 255/255
Loading 2/255
Hops 4
